RV.Net Open Roads Forum: Help me find a chair base hold-down, please
 > Help me find a chair base hold-down, please
Noel
Southern Oregon
Posted: 04/14/12 04:43pm Link  |  Print  |  Notify Moderator
Thanks for your replies, so far.
I was wondering why some wanted me to visit Winnebago/Lichtsinn and then I saw that my profile had our old 2004 W/I Sightseer. We traded that in nine months ago for our 2003 Dolphin.....but I never changed my profile info.......Until now.
Noel
2003 National Dolphin LX 6335, W22, 8.1L
rondeb
Pacific Northwest
Posted: 04/14/12 06:06pm Link  |  Print  |  Notify Moderator
I think why people are telling you to go to Winnebago is that they make what you are looking for. We just took out a small recliner out of a new 2012 Winnebago sightseer. The chair was hooked to the floor with a swivel bolted down bracket that allowed the chair to swivel out if you unscrewed the bracket or push back and tighten to travel. Winnebago has every part available that is in their coaches.
okeehandyman
south florida
Posted: 04/16/12 02:43pm Link  |  Print  |  Notify Moderator
I once held an object in place on the floor by drilling a clearance hole in the floor (after checking below to be sure there were no wires, pipes, etc.)and installing a couple of 3/8" "T nuts" under the floor. Then using a couple of moulded plastic knobs with 3/8" threaded bolts and steel pipe clamps. They were secure, quick & easy to use.
tahiti16
Camarillo, CA
Posted: 04/16/12 10:18pm Link  |  Print  |  Notify Moderator
Your chair sounds like ours. NRV put to footloops bolted through the floor with straps and plastic latches on them. I just set the chair over the straps loop them to latch and good to go. The hold down is to keep them from moving around not make them stable to ride in. Basically the idea is to not let the chair start moving.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
NobodyJr
Tampa, FL
Posted: 05/13/12 07:58am Link  |  Print  |  Notify Moderator
We own an '02 Dolphin, same chair, same dilemma. We couldn't see drilling any holes in that beautiful hardwood floor. So we got a nice thick round rug that fit the base (plus a few inches) perfectly and got some of that material used to keep rugs in place, kinda like a rubber mesh. We cut a piece to fit and placed it under the rug. That chair hasn't moved since. Ours has a lockdown on the side to keep it from rocing. No rocking, no sliding. And remember, no matter how tempting, that chair was never meant for occupancy while the coach is in motion.
JNW57
SOGN, MN
Posted: 05/16/12 11:10am Link  |  Print  |  Notify Moderator
I have 2 recliner/chair clamps removed from my MH when I had a new S/O floor replaced in 2005. They were never reinstalled. I just listed them on EBAY if you are still interested. Search for Item #130516842622.
2003 DISCOVERY 39L QUAD SLIDE
2003 CHEVY TRACKER ZR2 4x4
Blue Ox Aladdin, Brake Safe, Kar Guard
Wherever I happen to park
Posted: 05/16/12 12:25pm Link  |  Print  |  Notify Moderator
Considerations: You said it is a 3/4 or 1" Pipe base.. Ok, there are several different styles of pipe clamp. On this page: http://www.erico.com/products/cdmoz_dom_pipe_clip.asp there is a grid of different pipe clamps
The 2nd clamp in the top row
Use a bolt you can hand tighten (The kind with the really big plastic heads)
Or you can use one of the other clamps and two bolts or studs with wing nuts or.. Well many possible solutions.
Noel
Southern Oregon
Posted: 05/18/12 12:06am Link  |  Print  |  Notify Moderator
Thank you for your replies. I have not yet done this, but soon: I bought three sturdy J-hooks with nuts and large washers. Will drill thru the carpet into the compartment below (seems to be 3/4 in plywood, between) and secure the J-hook over the round base bars. Then secure from below with nuts and washers.
Pangaea Ron
Anacortes, WA, USA
Posted: 05/18/12 12:58am Link  |  Print  |  Notify Moderator
I used this to hold my chair base in place.
Gate bolts
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
