RV.Net Open Roads Forum: US Gear Unified Tow brake manual lever assembly help needed
Search only in Dinghy Towing
 > US Gear Unified Tow brake manual lever assembly help needed
mkc
TX
Posted: 04/13/12 11:32am Link  |  Print  |  Notify Moderator
The manual lever of the control module for our US Gear Unified Tow Brake has come off. We have a call into US Gear, but apparently their offices are closed today.
Does anyone have instructions on how to reattach the lever? It's not obvious, particularly getting the spring return set correctly.
Thanks,
Michelle
2003 Foretravel U320
BluegrassBill
Woodland, Wa. USA
Posted: 04/14/12 11:27am Link  |  Print  |  Notify Moderator
While working on my engine my jeans belt loop snagged the lever and pulled it off. I tried reattaching with no luck the spring was stretched. I tried finding a replacement but was unable. Probably have to buy a new unit, Expensive. I just do without the lever, No reason to use just the toad brakes anyway, Good luck.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
