RV.Net Open Roads Forum: Toy Haulers: Cracked holding tank-UPDATED, fixed it
Search only in Toy Haulers
 > Cracked holding tank-UPDATED, fixed it
EricRobinson8
Fountain Valley CA.
Posted: 04/13/12 11:32am Link  |  Print  |  Notify Moderator
I have a leak on the bottom of my fresh water tank, where the drain comes out. Is there a material or glue I can put on it to fix the leak? I was hoping this would be considerably cheaper than getting a new tank.
Thanks
* This post was edited 04/20/12 10:14pm by EricRobinson8 *
2006 F-250 CC PSD 4X4
2007 Raptor 299MP
Pullrite Superglide
LVRIDER
Sin City
Posted: 04/13/12 11:43am Link  |  Print  |  Notify Moderator
I would recommend mighty putty. There is also a version of it at home depot that is sold in the plumbing section. Comes in a tube with a red top. Just use it liberally over the whole area of the leak. I even used this to repair a large hole in my rzr rim and it is still holding air a year later!
Oasisbob
Portland Oregon 97266
Posted: 04/13/12 11:54am Link  |  Print  |  Notify Moderator
What ever you use be sure it is approved for fresh water as this is your drinking water supply. Also be confident it will hold. Personally I would replace the tank. Best of luck.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
gbopp
The Keystone State
Posted: 04/13/12 11:55am Link  |  Print  |  Notify Moderator
Another option is JB Weld.
judelaurenzo25g
Downey, CA
Posted: 04/13/12 12:06pm Link  |  Print  |  Notify Moderator
X2 JB water weld it claims to be safe for drinking water.
A ship in harbour is safe, but that is not what ships are built for.
LVRIDER
Sin City
Posted: 04/13/12 12:37pm Link  |  Print  |  Notify Moderator
Click ->Turns out is is a JB product
dedmiston
Valencia
Posted: 04/13/12 12:49pm Link  |  Print  |  Notify Moderator
Is it a flat surface? Can you use Eternabond tape? I used Eternabond to patch a leak on the top of my water tank over a year ago and haven't had any trouble since then. But you have it worse with a leak on the bottom. My leak on the top wasn't so bad.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
phillyg
Front Royal, VA
Posted: 04/13/12 01:14pm Link  |  Print  |  Notify Moderator
Some plastics can be "welded." Find out from the mfgr what type of plastic, and search for plastic welding and you may luck out.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Racerx11
Northern California
Posted: 04/13/12 01:15pm Link  |  Print  |  Notify Moderator
Try plastic welding maybe?
It's pretty soft plastic, should make a good weld.
shifter
so cal
Posted: 04/13/12 01:42pm Link  |  Print  |  Notify Moderator
If the tank is made of polypropylene welding is the only permanent fix, the other stuff might work, might not. You will find out which in the middle of a vacation trip.
