RV.Net Open Roads Forum: Toy Haulers: Cracked holding tank-UPDATED, fixed it
Search only in Toy Haulers
 > Cracked holding tank-UPDATED, fixed it
EricRobinson8
Fountain Valley CA.
Posted: 04/13/12 06:56pm Link  |  Print  |  Notify Moderator
Thanks for the suggestions......it is in a hard spot right next to the outlet drain, so i guess I will call Keystone and find out what type of plastic it is.
Thanks
2006 F-250 CC PSD 4X4
2007 Raptor 299MP
Pullrite Superglide
tmprkswyo
Southwest Wyoming
Posted: 04/13/12 07:06pm Link  |  Print  |  Notify Moderator
I had the same issue on my previous travel trailer. I tried plastic welding it. No much luck. JB weld held up for a little while until it cracked off. I finally ended up replacing it with a new tank. The new one cost almost $400 with shipping.
gmayer
Where my chair is
Posted: 04/13/12 08:52pm Link  |  Print  |  Notify Moderator
I had mine fixed at a local RV shop. They did something called (spun welding). Where they take a very fast drill and force the new fitting into the take to make a seal. I think it was around $150-$200.
Dirtclods
Newport Beach
Posted: 04/13/12 10:35pm Link  |  Print  |  Notify Moderator
Rust-Oleum Leak Seal Black Spray :http://www.homedepot.com/h_d1/N-5yc1v/R-........word=rust+toluim+leak+seal&storeId=10051 Works great I used it on my surf board.
EricRobinson8
Fountain Valley CA.
Posted: 04/20/12 10:20pm Link  |  Print  |  Notify Moderator
I found a place right by my house called Ronco in Tustin. They make tanks for all kinds of applications. I took it out and over there, where they cut the old drain out and put in a new one. As for holding up, they did what they do on all new tanks, so it is as good as new, possibly better, because in this process I realized the drain came down too far, and was hitting the axle when it compressed. So we shortened it and shouldn't have a problem anymore. They charged $30.00 for putting in a new drain and a new shorter valve. Thanks again for all the suggestions. So about my tires.......................
dedmiston
Valencia
Posted: 04/21/12 06:33am Link  |  Print  |  Notify Moderator
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
nayther
Burbank, CA
Posted: 04/23/12 10:20am Link  |  Print  |  Notify Moderator
For your truck, trailer or OHV?
Don't buy Chinese.
I like Nitto.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
