RV.Net Open Roads Forum: Tech Issues: Joining #8 wires
 > Joining #8 wires
bogen2
Edmonton
Posted: 04/13/12 01:29pm Link  |  Print  |  Notify Moderator
I am installing some #8 wire and am wondering what the best way to join 2 pieces together. Normally I would just do a butt splice with solder with a smaller gauge and with the heavy stuff for the batteries I've used terminal posts. This wire will connect my converter to the new battery terminal I've installed for my solar installation.
The existing wire just uses a wire nut to connect. I need to make 2 joins: to the pigtail from the converter on one end and the fuse (also #8) at the terminal block.
2006 Ford F150 Supercab
2010 Jayco Jayflight G2 23FB w/ Reese Dual Cam WD hitch
190w solar, 1000w PSW inverter, Prostar PWM controller
Matt_Colie
Southeast Michigan
Posted: 04/13/12 02:11pm Link  |  Print  |  Notify Moderator
I guess I am not sure what the issue is here. I don't like wire nuts that are out in weather, but other then that....
Are you talking about putting terminals on the cables you are adding?
If that is the case, find a friendly truck garage and ask if they can stake terminals of that size.
Or there is always McMaster Carr this page, look at the entire page
I have used these in places where I want the entire system to be field serviceable.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
chuggs
Posted: 04/13/12 02:20pm Link  |  Print  |  Notify Moderator
I've used the set screw butt joint devices...they usually come packaged with a piece of shrink wrap...that would be my recommendation. Slide the shrink wrap over one of the wires...strip the end...insert into the connector...tighten the set screw securely. Repeat the other wire... Slide the shrink wrap over the connector and heat it evenly til sealed.
Crazy Ray
Monroe,La
Posted: 04/13/12 02:30pm Link  |  Print  |  Notify Moderator
Go to HD get what is called Splicer Reducer there in electral department. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
hershey
Albuquerque,(fulltime) NM, USA
Posted: 04/13/12 04:56pm Link  |  Print  |  Notify Moderator
This is available at Lowes. It works very well and the shrink tubing also has a glue that makes the joint weatherproof.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
smkettner
Posted: 04/14/12 12:40am Link  |  Print  |  Notify Moderator
http://shop.genuinedealz.com/Items/gim-3........heat%20shrink%20butt%20splice%20-%2010pk
675 watts solar
Kalabin
Alaska
Posted: 04/14/12 01:13am Link  |  Print  |  Notify Moderator
I know this is over kill but we use H-Tap and C-Taps a lot at work for power distribution. Typical Scenario is coming from a battery distribution with 2AWG or larger, then H-Tapping the 2AWG to 4AWG or 6 AWG depending on the need. It's a permanent splice. Only down side is you need the crimper to do it!
If your wanting something more "professional" take a look at Thomas-betts website.
Otherwise I would just go with a simple #8 to #8 Butt-Splice with heat shrink and call it a day. You should be able to go to any electrical supply house and pick up a few of these. Thomas and Betts #8 (Red) Butt Splice
My personal opinion is to not go with a reversible splice. Especially if it's in an environment where it can move around. We have cabinets we build out that have lots of DC power connections, and per the vendors it's set screw / compression fittings. We almost "always" end up having to go out to the physical site after the DLC site has been placed and tighten up lugs. Go with a non-reversible mechanical splice and you never have to look at it again.
2008 Chevrolet Silverado 2500HD 6.0, 3.73, Firestone Air Bags, CCSB LTZ
SCVJeff
Santa Clarita, CA.
Posted: 04/14/12 02:52am Link  |  Print  |  Notify Moderator
x3
I keep a full set to splice the #6 around the surge guard if ever need be.
Jeff - WA6EQU
kneal44
EAST CENTRAL TEXAS
Posted: 04/14/12 06:38am Link  |  Print  |  Notify Moderator
i dident have a crimper but used bare metal crimp splices ..squeezedwith vice grips and soldered using small torch... taped and good to go. very good connection.
and put into high current service.... touched connection to see if it got any warmer then rest of cable... to make sure connectin was a good one.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
CJW8
Arizona
Posted: 04/14/12 07:40am Link  |  Print  |  Notify Moderator
I have used these in many places in my job and on my RV also. I used them on my roof to eliminate a junction box to parallel my solar panels to the single #4 downcommer. This saves additional holes in the roof to mount the junction box. As mentioned above, they can be found at HD or Lowes. They come in various sizes and as reducers also. The reducers are handy for reducing large cable to smaller wire to fit into solar charge controllers.
2013 F350 PSD FX4 SB CC, 18,000 Superglide
2003 37SP Forest River Sierra Toyhauler (40')
2008 Polaris RZR
405 Watts of Kyocera solar panels, Rogue 3024 Charge Controller
 > Joining #8 wires
