RV.Net Open Roads Forum: Fifth-Wheels: hitch question for you 5th wheel guys
 > hitch question for you 5th wheel guys
mobilefleet
on the road
Posted: 04/13/12 02:50pm Link  |  Print  |  Notify Moderator
I just bought a Valley 16K hitch to put in my 99 F250 longbed (8 ft bed). Currently I have 2 side toolboxes which are about 6 ft long. They extend above the rails prob. 6-7" or so. I'm thinking I will have to remove them but since I haven't picked up the camper yet (it is at an auction) I don't know if I can leave them on. The hitch can be adjusted height wise up another notch or two. Does anybody here tow a 5th with 2 side toolboxes intact? Would be nice to have my tools over the road. Camper is an 05 Forest River Salem/
laknox
Arizona
Posted: 04/13/12 02:54pm Link  |  Print  |  Notify Moderator
You'll almost certainly have to take out the tool boxes. Bed clearance on most FWs is a minimum of 6", though more is better if you can keep your FW level. See if you can swap for a cross-bed, flush box. Some neat ones that sit right at the rear of the bed and have a V in them to clear the king pin.
Lyle
1936 John Deere Model A
AZ T&T
Mesa, AZ
Posted: 04/13/12 04:19pm Link  |  Print  |  Notify Moderator
I have 2 saddle toolboxes in my truck, they are about a 1/2" below the bed caps and my pinbox would hit them if it sung that far.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
45Ricochet
North Idaho
Posted: 04/13/12 04:27pm Link  |  Print  |  Notify Moderator
I don't think you'll be able to even hitch up with the boxes in there.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
arizonakid
Stow Mass. USA
Posted: 04/13/12 03:27pm Link  |  Print  |  Notify Moderator
Problem is, fifth wheel builders and PU truck builders (even those with tow package option) don't get together so the damn things will match up.
Road Runners
Tampa Bay, Florida
Posted: 04/13/12 03:35pm Link  |  Print  |  Notify Moderator
I agree with those above. It is important that your fiver is as level, fore and aft, as possible when it is hooked up, and that you have at least 6 inches of clearance between the bed rail and the underside of the fiver. With your side tool boxes it will next to impossible to gain this 6 inches of clearance.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
CruiserJoe
Fredericksburg, VA
Posted: 04/14/12 06:59am Link  |  Print  |  Notify Moderator
Agree with all above, the boxes will have to go.
powderman426
ohio
Posted: 04/13/12 06:33pm Link  |  Print  |  Notify Moderator
On the Ram I have I was able to get a box that went across the bed behind the window and I also found that a short bed Tonneau cover was the perfect length for the rest of the long bed. Now I can keep things out of sight and the weather when not hooked to the trailer which I believe is a great benefit. Take some measurements as it might work on your truck also.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
azandy70
Green Bay WI
Posted: 04/14/12 06:22am Link  |  Print  |  Notify Moderator
A front over the rail box may work, but nothing above the rails will work on the back. As soon as you turn on a goofy road or driveway with a big elevation change, you truck rails may be real close. Ours even hit slightly just the other day when turning a sharp corner with a hill on one side of the intersection.
Jmho.
2011 F350 SRW 4x4 Crew cab short box
6.7
2010 KZ Stone Ridge. 36UL
gkenworth
Alberta
Posted: 04/14/12 06:23am Link  |  Print  |  Notify Moderator
I have 2 yukon (porkchop) boxes mounted on our shortbox superduty. they come back about 40 inches and stick above the bed 2 inches. any longer or taller would cause me grief.
* This post was edited 04/17/12 06:50pm by gkenworth *
IMHO
