RV.Net Open Roads Forum: Fifth-Wheels: refrigerator without thermostat - no temperature adjustment
 > refrigerator without thermostat - no temperature adjustment
arizonakid
Stow Mass. USA
Posted: 04/13/12 03:31pm Link  |  Print  |  Notify Moderator
I am looking for a replacement trailer - fifth wheel - and the last two I looked at had a Dometic refirgerator that had no temperature control thermostat ... had a clip inside that attached to the cooler fins ... so ... anyone got one of those ? how do they work? Any way to adjust the refrig or freezer temp?
Thanks for you information... Tom
Ka Ron
Kelowna
Posted: 04/13/12 03:39pm Link  |  Print  |  Notify Moderator
We have one and they work fine.
That is the temperature control. Slide up or down to adjust cooler or warmer.
Once you find the temp you don't have to adjust again.
Join Us For A Trip Down The RV Highway
therink
Rochester
Posted: 04/13/12 03:41pm Link  |  Print  |  Notify Moderator
Mine has the clip and supposedly you raise the clip and it lowers the temp, as heat rises. I have yet to see a difference in temp with my thermometer, no matter where I put the fin. I will say that once the fridge reaches cold temp, it keeps everything cold enough on the warmest days.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
bob213
Fresno, CA
Posted: 04/13/12 03:47pm Link  |  Print  |  Notify Moderator
If you find that the adjustment on the fins doesn't do the job you can get one of these:
Thermistor adjuster
RandACampin
Kathleen, Georgia
Posted: 04/13/12 03:57pm Link  |  Print  |  Notify Moderator
Yep slides up and down, however doesnt seem to work great as a thermostat. But the fridge works awesome and wouldn't deter me a bit.
ScottG
Bothell Wa.
Posted: 04/13/12 04:05pm Link  |  Print  |  Notify Moderator
Mine has no adjustment - and hasn't needed one in the 8 years I've had it. Just turn it on and forget about it.
Oh and it does have a thermostat - you just can't adj it.
Scott, Grace and Wesly
H0NDA eu2000i
Chuck&Gail
In the Colorado Mountains
Posted: 04/13/12 04:06pm Link  |  Print  |  Notify Moderator
We were concerned when buying a TT with that fridge, but everything else was EXACTLY what we needed so we bought it. Had it several years and near 9000 miles so far, in Canyonland deserts, and chilly Gaspe peninsula. It was worked great, and we've never adjusted anything. So far, so good.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Sandia Man
Rio Rancho, NM
Posted: 04/13/12 04:54pm Link  |  Print  |  Notify Moderator
Love our Dometic with temp adjust on fins. It cools perfectly in whatever weather from +100 degrees days to cold days with temps in the teens.
korbe
Northern California
Posted: 04/13/12 06:54pm Link  |  Print  |  Notify Moderator
Ours works just fine. Fiddled with the slider thing, didn't notice any change . No problems, no fix needed.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
arizonakid
Stow Mass. USA
Posted: 04/13/12 07:33pm Link  |  Print  |  Notify Moderator
Thanks for your responses -- sounds like I should not be concerned about this type of refrigerator (I guess Dometic knows what they are doing). ... Tom
