twogypsies
Anywhere the job takes us.
We bought the fifth wheeler 2 years ago but had it delivered. We have been living in it in one spot but now we are going to travel around the country. I just bought a 3/4 super duty truck with 1 ton suspension and brakes and when I hooked up the truck and took all the jacks up on the fifth wheeler I got a 2" drop in the bed. What would be the normal drop before you would install airbags to the rear?
edited 04/13/12 06:03pm by twogypsies *
SDcampowneroperator
South Dakota
2 " is about perfect. Your truck is designed for that, I would not change a thing. You will find the ride to be smoother than when empty.
John Bridge
Houston
Two inches is about what happens to my 1-ton, and I've got a pin weight of nearly 2 tons. I think you're fine.
Semi-"retarred" in 2006. :-) 2008 Newmar Cypress 5th wheel, 2008 Dodge diesel dually to pull it with.
twogypsies
Thank you, it just made me a little nervous.
twogypsies
What is the gross vehicle weight of your 5th wheeler?
ScottG
Bothell Wa.
SDcampowneroperator wrote: 2 " is about perfect. Your truck is designed for that, I would not change a thing. You will find the ride to be smoother than when empty.
X2, the first two inches is pretty soft for good ride quality when empty.
Scott, Grace and Wesly
H0NDA eu2000i
dqdick
Council Grove, KS
At some point you need to get your rig weighed. The decision on air bags or not should be made on how much weight you are shifting from your front axle. We were shifting 140# which was really not enough to worry about but I put bags on anyway and now we don't shift anything.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
smildrum
Durham,Maine
2500HD/1500 Durango=2"drop
slarsen
Indiana
I'm not arguing with the 2" others have stated. Just a personal preference: I added air bags to keep the drop down to one inch.
Vicious bumps on today's roads make me nervous without the extra support, plus I like to keep the headlights close to where they were intended.
If we all agreed on everything, wouldn't this be a boring world? And web site?
partsman01
Poco British Columbia
I had a two inch drop on my 96 gmc k2500 so sounds good to me.
