SoCalDesertRider
SanDiego, CA, USA
dqdick wrote: At some point you need to get your rig weighed. The decision on air bags or not should be made on how much weight you are shifting from your front axle. We were shifting 140# which was really not enough to worry about but I put bags on anyway and now we don't shift anything. If your hitch is mounted over or ahead of the truck's rear axle, you won't be removing any weight off the front axle. Only time a fifth wheel can cause the truck's front axle to lose weight is if the hitch is mounted behind the truck's axle, which is an improper installation, for any model of pickup and any model of fifth wheel hitch.
I fully agree on weighing each axle of the truck and the trailer axles.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
I'm with all the others on the 2 inches of drop being a-ok.
Only time to worry is when the truck drops to below level in the rear.
tjar66
Camarillo CA
I have a similiar drop on my 3500. I went with airbags to keepoff the overload spring the rebound was extremely rough on bigger bumps. The ride was night and day.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
SoCalDesertRider
SanDiego, CA, USA
7.3 psdman wrote: Mine goes down a lot more than two inches on a one ton. I am carrying about 2300# of pin weight from a 13000# fifth wheel. I think mine goes down at least 4" before it rests on the overloads. After having everything weighed out by RVSEF at a rally they said I'm in good shape as far as weight on truck and fifth wheel. They are the real experts at determining everything about weights in RVing. You can add Torklift Stable Loads, or Super Sway Stops from Super Springs company, to help with that problem.
These products are both extra tall polyurethane bushings that replace the short factory rubber bushings under the truck frame's overload spring bumper brackets. What these do is decrease the amount of free space between the overload spring bumpers and the ends of the overload leaf. This allows the overload springs to become engaged sooner, before the truck drops so low, which in turn keeps the truck more level instead of sagging so much.
Stable Loads-
Super Sway Stops-
Another way to solve the problem is to simply have your overload spring leafs re-arc'd at a local spring shop, so they are taller and engage sooner. This is really what the truck manufacturers should have done in the first place. Either that, or mount the frame bumpers down lower.
Yet another way is to replace the standard fixed-position overload spring frame bumpers with adjustable height frame bumpers. These are made by Dayton Spring and are sold by Stengel Bros.
Dayton adjustable height frame brackets-
Old-Biscuit
Across the USA
You have a 3/4 ton with 1 ton suspension........so I guess you have overload leaf on your spring pack.
With a 2" drop you should just be loading the overload spring which is right.......tow on and enjoy!
7.3 psdman
Northern Illinois
RCMAN46
NorthWest
Old-Biscuit wrote: You have a 3/4 ton with 1 ton suspension........so I guess you have overload leaf on your spring pack.
X2 I would not add air bags if they are going to hold you above the truck overload springs. You may find the trailer may buck as it goes into and out of the truck overload springs with minor bumps on our very smooth interstate highways LOL.
My 05 2500 HD Dmax has about a 2 inch drop with 2000 lb pin which puts me in a comfortable range. If you look at your truck unloaded you will most likely find it is a little high in the rear. With the 2 inch drop it most likely will be more level.
