RV.Net Open Roads Forum: Fifth-Wheels: Self-Adjusting Trailer Brakes?
 > Self-Adjusting Trailer Brakes?
slarsen
Indiana
Posted: 04/13/12 07:52pm Link  |  Print  |  Notify Moderator
I have a 2010 Montana Mountaineer. I just stumbled on a discussion about Dexter axles that says trailers, including RV trailers, under 15K pounds are typically equipped with self-adjusting brakes. It appears that this started in about 2008.
Does anyone know, or think they know, if my trailer is or probably is equipped with self-adjusting brakes? The rated gross weight is something like 12.5K pounds, I believe.
Traveler II
Minnesota
Posted: 04/13/12 08:20pm Link  |  Print  |  Notify Moderator
Yes, I would appreciate knowing if we have them also. How can you tell?
2011 Cameo 34SB3
2014 Ford 350 King Ranch (on order), Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2011 - 165
Nights Camped in 2012 - 142
Nights Camped in 2013 - 101
Old-Biscuit
Across the USA
Posted: 04/13/12 09:58pm Link  |  Print  |  Notify Moderator
Don't think they are 'standard' equipment........probably 'upgraded option'
Check your data sheet that lists components/serial numbers for the Dexter Axle info. then call Dexter and inquire.
You can pull the hubs and see if they have the adjusting cable/ratchet lever needed to actuate the star wheel.
Might be able to look thru back adjustment slot......remove plug, shine flashlight thru slot and look for a lever sitting on top of star wheel.
No cable/ratchet lever than no self adjust.......
Chuck&Gail
In the Colorado Mountains
Posted: 04/13/12 10:21pm Link  |  Print  |  Notify Moderator
My 2010 Outback does not have self adjusting brakes. I just greased a hub, so I looked at that stuff. I think my GVWR is 7700# or so.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
fla-gypsy
North Florida
Posted: 04/13/12 10:51pm Link  |  Print  |  Notify Moderator
Self adjusting brakes on a trailer would be an exception in my experience
rattleNsmoke
Western Conn.
Posted: 04/14/12 04:58am Link  |  Print  |  Notify Moderator
They have been pretty much useless on cars and trucks all these years. I wouldn't expect them to work on a trailer either. It's a lot easier to adjust brakes without that POS lever in the way.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Duck
Miami Lakes, Fl
Posted: 04/14/12 06:13am Link  |  Print  |  Notify Moderator
My 08 Hitchhiker and my current 13 Bighorn both came with self adjusting brakes. I had the Hitchhiker for 4 years and never had to manually adjust the brakes.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
Mile High
Denver, CO
Posted: 04/14/12 07:56am Link  |  Print  |  Notify Moderator
I heard that on the Montana Forum as well, at least for the Montana around 2008. I don't know about the Mountaineer. My 2007 are manually adjusted.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
pcm1959
home
Posted: 04/14/12 05:38am Link  |  Print  |  Notify Moderator
Dexter makes the brake assemblies for 6klb and 7klb pound axles. It seems the RV manufacturer always has advertised this feature, if so equipped, by placing a sticker on the fender of the RV or made mention of it in the sales flyers. I doubt you have them but you might call Keystone and ask. They should know. Phillip
2011 Silverado Crew 3500 SRW Duramax/Allison
2011 Carriage Cameo 31KSLS
Jacksonville, FL
tnance
Nixon/Texas
Posted: 04/14/12 06:48am Link  |  Print  |  Notify Moderator
Self adjusting brakes were standard on my custom Teton. (Dexter 10K axles with Dexter Air Flex suspension) I have never had to adjust the brakes on my 2004 Teton. The brakes adjust when you apply the brakes while backing up. Self adjusting brakes could have been an option on your trailer.
2005 Freightliner M2 106 class 7 HDT
2004 Teton Sunrise Grand
Jeep Wrangler toad
...PICTURES...
