RV.Net Open Roads Forum: Class C Motorhomes: How to seal marker lights?
 > How to seal marker lights?
tracyb-oh
Cincinnati,Ohio
Posted: 04/13/12 08:35pm Link  |  Print  |  Notify Moderator
Any ideas how to seal the yellow marker lights that are on the front of our cab over? It seems that as soon as we replace one, another blows off. I didn't think they should be totally sealed in case you had to change the light bulb, but I'm tired of replacing them all the time. Thanks.
Tracy and T
Jayco 2001 Class C 3150J Designer
2007 Honda CRV
"The Girls" Honey and Crystal our dachshunds
fordsooperdooty
Posted: 04/13/12 09:57pm Link  |  Print  |  Notify Moderator
Some dabs of clear silicone caulk should do the trick, as the lens will remove with only a slight effort if a bulb needs to be changed.
toolman1
Cerritos, CA.
Posted: 04/13/12 10:03pm Link  |  Print  |  Notify Moderator
EZ, replace em with LED lights. The circuit board is sealed in epoxy, and will work nearly forever (even under water). I did this cuz quite frankly, I got tired of the bulb contacts rusting out, and the lights constantly not operating. BEST external change to the coach I have performed!
See ya out there!!
Hooliville member #128
Gary & Lynne.
'04 Dolphin 5320 WH-22 370W Solar
22' Mighty Mover Trailer, 60W. Solar.
Sand Sprite 4. 2.3L EFI sand buggy
'04 Polaris Predator
'84 Jeep CJ.
2011 Black Lab "Lucy" for both of us
old guy
Oregon (pronounced Or e gun)
Posted: 04/13/12 11:08pm Link  |  Print  |  Notify Moderator
do not use a lot of sealant, you do and will have to be able to get the lense off in the future. just a small dab will do the trick. You must drive very fast or something, in all the years I have been Rving, I have never lost a lense and I have never used a sealant
pnichols
Santa Cruz Mountains
Posted: 04/13/12 11:29pm Link  |  Print  |  Notify Moderator
Just a bit off answering the OP's question ... but more importantly than sealing the light bulbs ... how does one (absolutely "forever") seal around the cabover marker lights' wires that snake inside the RV so water can't ever find a path crawling down these wires so as to slowly rot the walls/flooring of the cabover area - especially when driving during rain storms?
Phil, 2005 E450 Itasca 324V Spirit
Replant
Someplace
Posted: 04/13/12 11:37pm Link  |  Print  |  Notify Moderator
x2. The factory drills a rather large hole for the bulb socket to fit into. When installing the LED lamps I cut a patch of Eternabond tape large enough to cover the hole and cutting a slit in the center of the patch to suspend the wiring away from the sharp edges of the hole. Now they are watertight and will not short out.
tracyb-oh
Cincinnati,Ohio
Posted: 04/14/12 06:36am Link  |  Print  |  Notify Moderator
good question pnichols as I have that concern too. Peplant has the answer I think. I didn't think about Eternabond as the solution. Between that and the caulk I should be in good shape. Thanks everybody.
ret-miner
ontario
Posted: 04/14/12 08:56am Link  |  Print  |  Notify Moderator
Alittle smear of silicone around the inside of lens does the trick
fisher60
Plant City, Florida
Posted: 04/15/12 06:57pm Link  |  Print  |  Notify Moderator
ditto on that and I've never replaced a bulb either.
'01 Dutchman Express 28A, Borg Chrome Dually Valve Stems, Pacific Dualies Wheel Simulators, '06 Tuscon, '06 FLHTC/I
Good Sam Life Member
oldtrucker63
Harlan Kentucky
Posted: 04/15/12 08:14pm Link  |  Print  |  Notify Moderator
X 2 here It cost a bit but well worth every penny.
Without Trucks,....America Stop's
