RV.Net Open Roads Forum: Class A Motorhomes: DP oil change
 > DP oil change
trickto322
Sioux Falls,S.D.
Posted: 04/13/12 10:49pm Link  |  Print  |  Notify Moderator
I had this done before but cannot find the paper work. How much do you pay for an oil change for a DP and the generator?
wny_pat
Western NYS
Posted: 04/13/12 11:50pm Link  |  Print  |  Notify Moderator
I'd say that you need to tell us the type of engine and how many gallons or quarts it holds.
RayChez
Barstow, Ca. USA
Posted: 04/14/12 12:27am Link  |  Print  |  Notify Moderator
Need more info as to what engine are you talking about. My caterpillar 3126 E holds 19 quarts of oil with the filter change.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
squeakkos
parker az
Posted: 04/14/12 04:50am Link  |  Print  |  Notify Moderator
ISM 39 qts
Ivylog
Blairsville, Ga. USA
Posted: 04/14/12 05:29am Link  |  Print  |  Notify Moderator
OP, I see now why you do not have the info for your rig in your signature: "8 RV's since 2000" BUT it sure would help. Next to doing it yourself, looks like SpeedCo is the most reasonable.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Doug and Cassi Glass
Clifton Forge, VA
Posted: 04/14/12 06:27am Link  |  Print  |  Notify Moderator
CW charges $89 and up for gen oil change, probably more now that oil is sky high. My 7500 Quiet Diesel holds 3 quarts, so about $15 for oil, another $10 for filter, $10 for labor for the CW mechanic. In other words, a minimum of $50 profit for CW.
You can do the gen yourself in about 20 minutes including cleaning up the mess.
Any local garage will do it for a lot less than CW. The engine depends mainly on quantity of oil.
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 04/14/12 12:01pm Link  |  Print  |  Notify Moderator
Just had the Speedco service for 250 bux. That included 22 quarts of RotellaT, 2 Fleetguard fuel filters, a Donelson oil filter, air filter, chassis lube,tire pressure check, and oil analysis
Big Katuna
Deland, FL
Posted: 04/14/12 12:40pm Link  |  Print  |  Notify Moderator
The $190 price is what I paid a year ago. It may have gone up. And that doesn't get you CAT or Cummins filters; there is an up-charge for that. I also don't get a break for only using 19 qts, which doesn't seem fair. Seems like I should be able to bring a gallon jug but he said they wouldn't fill it.
My Kharma ran over my Dogma.
lanerd
Newport, OR
Posted: 04/14/12 10:24am Link  |  Print  |  Notify Moderator
Boy, that is a good deal. 40 quarts of oil here will run close to $4/qt ($160) and the fuel and oil filters will run another $30 to $40 bucks. Doesn't leave much for labor.
I always do my own, getting the Rotella from Walmart and all the filters (oil, 2 fuel, air, and hyd (ps) and also all for the generator too, for about $100 from filterbarn.com and will spend most of the day doing the job. I once had a CAT place do this and they gouged me for over $600 bucks.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
Big Katuna
Deland, FL
Posted: 04/14/12 07:29am Link  |  Print  |  Notify Moderator
I do the genset myself; really easy. The annual chassis oil change; fuel filters, lube is a Speedco type place and it is $190 for up to 40 qts. of oil, including two fuel filters, oil filter and lube.
The Freightliner dealer across the street charges about $300 for the same service and takes two hours longer.
 > DP oil change
