RV.Net Open Roads Forum: Class A Motorhomes: black tank cleaning
 > black tank cleaning
ArchHoagland
Clovis, CA, USA
Posted: 04/14/12 10:07am Link  |  Print  |  Notify Moderator
I fill my black tanks (I have two) completely full with soap and softener mixed with water and let sit for at least 24 hours.
Then drain.
I don't use bleach as I've seen some bad reactions with bleach and certain cleaners plus sterilizing the black tank isn't what I wanted to do.
I buy my softener and detergent at the 99 cent store.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Pawz4me
North Carolina
Posted: 04/14/12 10:26am Link  |  Print  |  Notify Moderator
Bleach isn't a very good cleaner at all. It's an excellent disinfectant, though.
Me and the DH
Two boys and two dogs (and two cats who prefer to stay home)
2008 Forest River Georgetown 350DS (bunkhouse model)
2001 Honda CR-V
kidkasha
Ventura County
Posted: 04/14/12 11:32pm Link  |  Print  |  Notify Moderator
What about the solutions at Walmart, do they work??
Finally
Arkansas
Posted: 04/15/12 12:20am Link  |  Print  |  Notify Moderator
A Tiffin Tech recommended Pine Power. We use that along with Calgon liquid water softner. The Calgon has a "slicky" feel to it, which not to be "indelicant" kind of "slicks up" the commodes and tanks. We clean the commode with one third Dawn, one Third Calgon, and one third Pine Power. We mix this together in an empty squirt bottle. Sometimes we will squirt some down each drain.
When we get home we fill the grey and black water tanks with water, and soak over night with Calgon and Pine Power, then dump both tanks. We have never had an odor problem.
2012 Tiffin Phaeton 40QBH
2005 Tiffin Phaeton Sold
2009 Lincoln MKX
and Milli
computerbug
Sarasota
Posted: 04/15/12 01:34am Link  |  Print  |  Notify Moderator
vinegar and baking soda leave it till the next dump. This really cleans the sensors and any thing else, then put your fabric softner in.
wheelman16
Boulder City, NV
Posted: 04/14/12 01:41pm Link  |  Print  |  Notify Moderator
After dumping the black tank I would always smell an odor when refilling the tank partially with water. I just dumped the detergent/bleach/water mixture after sitting about 6 hours and it did the trick, no odor what so ever. You can debate this all you want but the bleach worked for me. Thanks for the replies. Bob.
Busskipper
Arnold,Md
Posted: 04/15/12 09:49am Link  |  Print  |  Notify Moderator
This system (GEO) has worked well for us, and hundreds of others, for years;
https://sites.google.com/site/cbruni/
JMHO,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
deandec
Northern CA
Posted: 04/15/12 10:50am Link  |  Print  |  Notify Moderator
We have never cleaned the black tank with chemicals in 10 yrs and 65,000 miles and use no chemical additives except when requested by the RV park (one only). We do have a tank water flush system that I use periodically.
I am not sure what is accomplished with bleach, unless you are converting that tank to some other use?
Dean
95 CC Magna, Jeep GC
sowego
northwestern corner of the Nebraska panhandle
Posted: 04/15/12 07:17am Link  |  Print  |  Notify Moderator
Instead of bleach try Dawn or some other general purpose cleaner as previous posters suggested. Detergents and water softeners will help release the waste from the sides and bottoms of the tank better than bleach.
The laundry deteregent and bleach should indeed help clean the tank but you really don't need the bleach. Bleach is generally used to sanitize the fresh water system.
If you use bleach in your black tank you will need to rinse it very well if you usually use a black tank treatment as there is a possiblity that the combo of bleach residue and black tank additive may not be a good mix.
* This post was edited 04/15/12 08:02am by sowego *
2002 Tiffin Phaeton
2005 Malibu Maxx toad
214mrj44
quinlan,tx.
Posted: 04/15/12 08:13am Link  |  Print  |  Notify Moderator
This works for me. When we get home from a trip and not going anywhere for a month or two I fill tanks full of water, put i/3 bottle of ridx in each tank(i have 3)let sit for 3 or4 weeks and dump. Runs out like melted ice cream .A couple renses, spotless. Wont work for everyone,but works for me.I dump in my septic system. I use no chimicles lots of water when on road works well also.
