RV.Net Open Roads Forum: 2002 Dodge Cummins 2WD Extended Cab Longbed 6 speed stick
Search only in Tow Vehicles
 > 2002 Dodge Cummins 2WD Extended Cab Longbed 6 speed stick
jspringator
Versailles, KY 40383
Posted: 04/14/12 09:41am Link  |  Print  |  Notify Moderator
I'm looking at a 2002 Dodge Cummins 2WD Extended Cab Longbed 6 speed stick with 150,000 miles. Anything special to look for on this model? I know to ask about lift pump (fuel pressure) maintenance. Do the 2wd have the front suspension issues of the 4WD? It won't be a daily driver.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion 4.30 LSD,V-10,2WD,RAS,5-Star tuner
Honda EU2000 & EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
"Scout" Springer Spaniel
ScottG
Bothell Wa.
Posted: 04/14/12 10:03am Link  |  Print  |  Notify Moderator
That's a nice truck and even has one of the fairly rare NV5600 heavy duty trannys. Sounds like a great two vehicle.
As far as front end issues, all heavy diesel trucks end up at some point in their lives needing the same stuff any other truck needs.
Scott, Grace and Wesly
H0NDA eu2000i
jspringator
Posted: 04/14/12 04:25pm Link  |  Print  |  Notify Moderator
He is going to check to see if it has been replaced. What are these trucks worth from a dealer? I've been watching for a while and haven't seen one this nice
45Ricochet
North Idaho
Posted: 04/14/12 04:48pm Link  |  Print  |  Notify Moderator
Its only a matter of time before someone brings up erroneous information about a dowel pin or block 53 problem. That 2002 didn't have them, only that lift pump problem which was common. They actually make aftermarket pumps to correct the flaw. I'm not positive of the year (2005?) they started putting them in the fuel tank which corrected the problem.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
boogie_4wheel
SLC, Utah
Posted: 04/14/12 03:08pm Link  |  Print  |  Notify Moderator
The LP are common problems. There really in no maintenance for the LP... What are you going to ask about it, other than how many times it has been replaced?!
Nothing special on the front ends other than packing wheel bearings every once in a while.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/14/12 10:09am Link  |  Print  |  Notify Moderator
In addition to the 5.9 24 valve diesel and NV5600 tranny, that truck will also have the Dana 80 rear axle, with disc brakes.
The 2wd trucks use a completely different front suspension than the 4wd trucks. The 2wd's use upper and lower a-arms with coil springs, instead of a solid axle with coil springs and 5-link control arms. I would still inspect for possible worn out a-arm bushings, ball joints, tie rod ends, or loose steering box.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
jspringator
Posted: 04/15/12 03:36am Link  |  Print  |  Notify Moderator
Whats a good price? Asking $11,900. Retail is $10,500, Sometimes in older specialty vehicles the book is too low.
FishOnOne
Katy
Posted: 04/14/12 07:50pm Link  |  Print  |  Notify Moderator
You may want to give the dashboad a look over for cracks...
http://www.youtube.com/watch?v=NgqpoJhufog
Yes the 2wd's have ball joint problems, but aftermarket ones will fix this problem for good.
Good Luck..
Ram4Sam
Redlands, Calif
Posted: 04/14/12 09:17pm Link  |  Print  |  Notify Moderator
If it is a good price, buy it. Rear disc brakes, good trans, big rear end. The lift pump is/was the only concern, which is easily fixed. Put an exhaust brake on it and you will have a darn good tow rig. If it has the 3.55 gear and you are keeping the trailer in your signature, it will be a great combo.
Sam
2001.5 Dodge QC2500 coal burner, 6spd,BD brake,a pile of other stuff!
little black box, K&N'd,only smokes a little....
2008 Thor Jazz 2870UK 5er
Driving a Dodge Cummins since 1991...
camping man
Central Fla.
Posted: 04/14/12 05:00pm Link  |  Print  |  Notify Moderator
Just put one of these on the fuel line connection.http://www.genosgarage.com/BD-LED-LOW-FU........INDICATOR-985-12/productinfo/BD-1081130/
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
