jerem0621
Sequatchie, TN
Do people seriously go out of their way to flogg the 6.0. Geesh. I guess no other brand has ever experienced an engine failure. The damaged discribed by the op is not a typical 6.0 or any other type motor failure.
With barely 100k miles on an 05 tow truck?? On motor number 2?
Must not be much business to have a truck for 7 years and only have 100k on a work truck.
I simply don't believe it.
Or the owner is terrible at maintenance and don't change the oil in a truck that gets driven what 15k miles a year?
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Wills250psd
walnutcove NC
I know where there is a neverending pile of 6.0's that all had major engine falure, its at my local ford dealer. BTW my 04 left me on the side of the road many times. Bashing no, truthful yes.
Dufus
Duncan, Ok
Mine revs to 3K all the time pulling up hill with my 17K 5th wheel. Still got all the valves. Go figure.
2003 F450 6.0L Turbo diesel / Western Hauler
2001 EXCEL 33RTO
45Ricochet
North Idaho
FishOnOne wrote: Something about this story from the OP sounds fishy... Dropping a valve is something I never heard happen on the 6.0 psd.
Now I've heard of Cummins dropping valve seats causing some nasty catastrophic failures!
Dropped valve
I'll let you supply a link to your second statement.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Flashman
Tucson, Aizona, USA
Wills250psd wrote: I know where there is a neverending pile of 6.0's that all had major engine falure, its at my local ford dealer. BTW my 04 left me on the side of the road many times. Bashing no, truthful yes.
I think it is time to say that the Ford 6.0 is much worse than the old 1990's Chev 6.5.
The worst diesel engine of all time - except for maybe the Ford 6.4.
NavyDood
NW of DFW
gbopp wrote: Turtle n Peeps wrote: ScottG wrote: A post like this does nothing more than inflame people.
Or warn them.
x2 X Infinity
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
Wills250psd
walnutcove NC
Flashman wrote: Wills250psd wrote: I know where there is a neverending pile of 6.0's that all had major engine falure, its at my local ford dealer. BTW my 04 left me on the side of the road many times. Bashing no, truthful yes.
The worst diesel engine of all time - except for maybe the Ford 6.4. I think the 6.0 is not as good as the old GM diesels JMO. and for the 6.4 If properly set up is OK but will never match the reliability of the 7.3 again JMO, but my 6.4 has 2x the hp/tq that the stock 7.3 had, and with more( power) you sometimes get less(reliability). So far no mechanical problems with mine but it has had several other probs.
FishOnOne
Katy
45Ricochet wrote: FishOnOne wrote: Something about this story from the OP sounds fishy... Dropping a valve is something I never heard happen on the 6.0 psd.
Dropped valve
No problem:
Cummins Valve Seat Failure
Cummins Valve Seat Failure #2
Cummins Valve Seat #3
Cummins Broken Valve Seat #4
Jarlaxle
New England
benalbert wrote: Trans shifted out of overdrive going up a hill... Normal
Engine reved to 3000... Normal
What tuner was on the engine?
The engine was 100% stock except for exhaust rerouted to clear the hoist and a high-power alternator to run the strobes.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
larry barnhart
wenatchee. wa usa
Dropped valve
fact is cummins had had many engine failures in MH's. cummins make a ton of engines but nothing is perfect.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
