RV.Net Open Roads Forum: Travel Trailers: Battery Life Expectancy ???
 > Battery Life Expectancy ???
batesrt
ohio
Posted: 04/16/12 08:56am Link  |  Print  |  Notify Moderator
Anyone know where I can buy a DC fan (my RV dealer doesn't sell them...any regular stores like Walmart or Lowes etc ?
Will a fan that plugs directly into the cigarette lighter outlet have the same amp-saving effect?
Huntindog
phoenix arizona USA
Posted: 04/16/12 01:34pm Link  |  Print  |  Notify Moderator
I had a small one about 6" or so a while back in my truck. IMO, you won't be happy with one.
Moving air takes energy. It doesn't really matter whether it is 12 or 110 volts. 110 volt fans are much more powerful, reliable and easier to get. IF, and this is a big IF you could find a 12 volt fan that moved the same amount of air that your 110 volt one does,,,you would find that the energy draw from the battery is about the same. The only difference would be the amount that your inverter is consuming, about 10-20%.
Bottom line is you need more battery capacity or a small generator.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
batesrt
ohio
Posted: 04/16/12 02:08pm Link  |  Print  |  Notify Moderator
Son of Norway wrote:
Chakara stated your problem exactly. Try using a couple of DC fans.
Miles
Where do you get these??? My RV dealer doesn't have them
batesrt
ohio
Yeah battery is my only option. Would a 6v golf cart type battery be best then, as opposed to a regular deep cycle battery? Looks like they have more Amp Hours, but not sure if I have to do anything differently to hook it up? Do I have to have two of them?
Chakara
New Mexico
Posted: 04/16/12 09:04pm Link  |  Print  |  Notify Moderator
Yes - 6V requires 2 batteries. Search 12V Side of Life.
Fans can be purchased at most automotive sources - local or online.
-Chak
- 2005 Dodge 2500 5.9 standard
- 2010 Starcraft Autumn Ridge 246RKS 28'
Link to my Blog with Techie stuff like LED's and Boondocking
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 04/17/12 09:07am Link  |  Print  |  Notify Moderator
Google them and you can find just about every brand made.
Here is one made by Fanstic Vent - called Endless Breeze that Camping World carries and Adventurerv.net has it even cheaper.
http://www.adventurerv.net/fantastic-vent-endless-breeze-fan-p-1456.html
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
batesrt
ohio
Posted: 04/17/12 09:21am Link  |  Print  |  Notify Moderator
And if i get this one and plug into the cigarette adapter, and it's a 1amp fan, it's only going to pull 1amp ?
(Unlike my current setup, where my 1amp 110v fan is actually pulling 10amps due to the power inverter it plugs into)
CA Traveler
The Western States
Posted: 04/17/12 09:38am Link  |  Print  |  Notify Moderator
Yes. Just saw a 8" DC fan in a truck stop so that is another source.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
bryanl
Reno, NV
Posted: 04/17/12 12:15pm Link  |  Print  |  Notify Moderator
re: "Preferably golf cart 6 VDC deep cycles."
there is so much bad information on this ...
Usable battery capacity is about 12 watt hours per pound and the battery voltage (6 or 12) is irrelevant. Battery life is also not a matter of voltage.
If you use proper units for power (watts) and energy (watt hours), it is a lot easier to make sense of things.
Battery energy capacity is rated for draws of about 1 watt per pound. Higher draws mean less available energy. You should only use about half the rated energy (the battery gets down to 12,0 - 12.2 volts after at least a half hour of no significant charging or discharging) for best battery cost efficiency.
A roof vent fan is a good way to improve air circulation in the rig. A 12v table fan such as Fantastic Fan makes is very good for a cool breeze to sit in. These can run at up to 100 watts or so.
A fan from a defunct PC can often be used in the refrigerator vent to help the fridge keep its cool. These can run about 10 watts.
Keep in mind that battery life is degraded when its temperature gets above 90F.
An inverter usually has about a 10% efficiency loss. If you use one of these, it should be connected directly to the battery with proper wiring.
A typical power outlet, cigarette lighter type plug in an RV is usually rated for no more than 100 - 150 watts.
There just isn't that much energy storage in lead acid batteries to do much so keeping your expectations in line with reality can be a learning experience.
Bryan
HappyTrails2U2
Posted: 04/17/12 12:33pm Link  |  Print  |  Notify Moderator
bryanl wrote:
Usable battery capacity is about 12 watt hours per pound...
Pounds of what?
