RV.Net Open Roads Forum: Hybrid Travel Trailers: Hitch ball stuck in receiver
Open Roads Forum  >  Hybrid Travel Trailers
 > Hitch ball stuck in receiver
drenjoey
Gray, Maine
Posted: 04/14/12 01:24pm Link  |  Print  |  Notify Moderator
This morning, I decided to install an electric tongue jack. To do so, I hitched my truck and did the work. When time came to unhitched, the ball was stuck in the receiver.
I moved a bit forward, but still no luck. I finally decided to remove the pin that holds the hitch and let the whole thing slide out. (Hope I made my story clear.......Still a lot of French in me).
1-Did this happened to anyone, and if so, is there a better solution.
2-Do some of you grease the receiver?
Thanks
Dre
skipnchar
Topeka or somewhere else
Posted: 04/14/12 01:30pm Link  |  Print  |  Notify Moderator
The BALL should always be greased but if you merely hitched to the truck to work on the trailer that is not likely the base CAUSE of your problem. Most usual cause is pressure on the ball (forward or to the rear). You say you moved a little forward but maybe you needed to move backward to relieve the pressure. I'd try that first. Now I SAY this assuming your ball is stuck in the coupler of the trailer. Some couplers have adjustments for how tightly they grasp the ball but it is rare for them to need adjusting is they've BEEN working correctly. I would be VERY cautious about making any adjustments because too loose and a disconnect could easily occur.
Good luck / Skip
ScottG
Bothell Wa.
Posted: 04/14/12 01:38pm Link  |  Print  |  Notify Moderator
Mine gets stuck all the time - sometimes I have to jiggle things to get it to release. Or, I just use the elect. jack to force it off.
Scott, Grace and Wesly
H0NDA eu2000i
old guy
Oregon (pronounced Or e gun)
Posted: 04/14/12 06:15pm Link  |  Print  |  Notify Moderator
you just have to get a bigger hammer. I have pried my off many times. this happens if you don't grease the ball.
LAdams
Northern Illinois
Posted: 04/14/12 09:36pm Link  |  Print  |  Notify Moderator
Grease will help and sometimes if the trailer is in tension with the coupler, it may be necessary to back up a bit or pull forward a bit to unload the tension off the hitch...
There is also an adjustment for ball tightness on most hitches... Look under the coupler and you should see a square adjustment nut... You want this adjustment to be snug so that the ball won't pull out, but not so tight that it will not release the ball... Check it out - it could be part of the problem...
MAKE SURE you have it adjusted properly - too loose could cause an unwanted uncoupling of the TT and that would be disastrous...
Here's a little procedure that explains it...
Coupler Nut Adjustment
Les
* This post was edited 04/15/12 03:52pm by LAdams *
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
drenjoey
Gray, Maine
Posted: 04/15/12 03:20am Link  |  Print  |  Notify Moderator
Thanks for the replies.
I'll start by greasing the ball and take it from there. I don't want to play with adjustments if I don't need too...............Nice to read I'm not the only one with this problem.
Dre
RoyB
King George, VA
Posted: 04/16/12 10:04am Link  |  Print  |  Notify Moderator
Didnt I read somewhere some folks leave it all hooked up including the WDH items etc and never uncouple the ball. Just pull the pin like you did drive away from it... Then you wouldnt have to hook up the WDH thingie...
My POPUP is too small for me to worry about the WDH and my other trailer was the Fifth Wheel so I havent had to mess with the WDH yet... Maybe I read all that wrong...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
drenjoey
Gray, Maine
Posted: 04/16/12 02:26pm Link  |  Print  |  Notify Moderator
The moment I pulled the pin and moved forward, the hitch fell on the ground.
