bob2194
Lawton, Oklahoma
How do you put a level on a trailer with a slide. Should the level show the trailer level before the slide comes out? Or should it show level after the slide comes out? I was thinking it would be better to have the level show level when its a little higher on the slide side, so when the slide come out its not too low on the slide side. Does that make any sense? what do you do?
Thanks for the help.
Bob
20 year U.S Army veteran and still working for the Army.
2007 Terry 270 FQS Pulled by 2008 F-250 5.4
Equal-i-zer Hitch
rexlion
Broken Arrow OK
It should show level when the trailer is level. And that is the catch, of course. How to know when your trailer is level, so you can install a level level! Do you have a level spot to park it? Then get out the carpenter's level and lay it across the bottom of the trailer frame, and hope they built it correctly...
garysol
Avon Ohio
Level is level. Park the trailer on a flat parking area and grab a carpenters level. I like to lay mine across the inside floor of the trailer. Once you are assured the trailer is flat per the carpenters level go ahead and mount your RV level.
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
Chris Bryant
DeLand, Florida, USA
It has to be level, but you can make a mark where it needs to be before running the slide out.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
CincyGus
Cincinnati
I understand what your saying. Level changes once the slide is out. Your wanting it level after the slide is out. Here's what you do:
1) Get the trailer level with the slide out.
2) Attached your level and mount it so it reads level.
3) Put your slide back in.
4) Note how much out of level you are now and mark a line in the center of the bubble on the level with a permanent marker.
The mark now becomes your new "level" mark for before the slide is put out. If you center on that, once the slide it put out, you should see the bubble center on the actual markings on the level.
Don't obscess over this. The main thing is get it close. My wife says I'm unbalanced all the time so on some days, the trailer helps me, some days it makes me a little more so
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
rfryer
Phoenix
I don’t have a slide and maybe there’s something unique about leveling them that I’m not aware of. But the main reason for leveling the TT is for the frig when you’re camped. So your slide would be out then and it seems that would be the proper configuration to level it.
I first used the frig itself to level the TT perfectly, and then attached the level on the front to match. When I actually camp, though, I’m satisfied if I get level within half a bubble. Seems to work, my original frig lasted 22 years before I had to replace it.
SCClockDr
SC UpState
How I did it!
Blocked up the wheels with wood strips till the stove top was level. You need to stand in the center of the trailer to read the level or your weight will contribute. I used a digital level.
Now install your side to side level.
BTW all 4 corners should be jacked solid before you deploy the slide.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, PD 9260 Upgrade, 2 Gal Accum., WiFiRanger GO/Mobile/SKY
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart, Cobra (19).
USN Ret
LarryJM
NoVa
CincyGus wrote: I understand what your saying. Level changes once the slide is out. Your wanting it level after the slide is out. Here's what you do:
Mine doesn't, but I use real screw jack stands to support my frame and not those useless crank down stabilizers that have all the pivoting joints and slop in them.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
bob2194
Lawton, Oklahoma
thanks for all the replies. So I level it with the slide out then put on the level.? Is that correct?
LAdams
Northern Illinois
Like the man said - level is level... The only thing to determine is what are you basing level on??? I base mine on the fridge since it has to be level to operate properly without going into self-destruct mode... I put one of those round bubble levels in the fridge freezer compartment and level from there...
When I get the fridge level, I install the side to side and front to back levels...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
