CincyGus
Cincinnati
bob2194 wrote: thanks for all the replies. So I level it with the slide out then put on the level.? Is that correct?
Bob, It just depends on what is most important to you to be level.
The frig will work fine as long as it's within a few degrees of level. The slide will work fine if it's not perfect either. There is some tolerance built in for being a half or full bubble off level without it being a major problem in any way.
Doing it the way I stated above will give you a level slide out and slightly off level fridge most likely. Doing it by leveling in the fridge and mounting your levels will make sure the fridge is always perfect if your levels are reading centered and your slide may be off just a tad. Your likely always going to have something off just a bit but it's not a big deal at all so mount them which ever way works for you, take it camping and level it as close as you can and enjoy it!
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
Ron3rd
Upland, CA USA
JMHO, but I would level the trailer first and put you bubble level on (Hoppy, etc) and go camping. When you pull your slide out, with the stabilizers down, the level should not change much, if any, and if it does, something's going on IMO. You trailer does not have to be perfectly level, and I doubt many are. It should just be fairly close.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
patinlouisiana
Baton Rouge, La
Perhaps we are missing the OP's question?
Sound to me like he thinks the weight of the slide will tilt his trailer. On mine once I'm level and have 4 jacks down the slide has no effect open or closed. I do see some people put jackstand under their slides but we do not.
BTW I have those stick on vials that I have yet to install.
For now we just use the bullseye on the floor.
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
dieseltruckdriver
Black Hills of SD
Learned this tip on this board. Level the stove top so the cook doesn't have to fight stuff running to the sides of the pan. The fridge will be happy there also.
My thoughts, if your slide changes your level, level the trailer with a torpedo level with the slide out, then run the slide in and then attach your bubble level. That way when you "level" your trailer when you park, it will be correct after you run your slide out. Why worry about what the level says after the fact?
1995 F-250 7.3 Powerstroke
2000 Arctic Fox 27-5L
bob2194
Lawton, Oklahoma
Thanks for all the replies. What a good amount of ideas. I am going do what dieseltruckdriver, and cincyjus said to do, thanks for all the help!!
20 year U.S Army veteran and still working for the Army.
2007 Terry 270 FQS Pulled by 2008 F-250 5.4
Equal-i-zer Hitch
Mootpoint
Somewhere in North America enjoying the life!
Most instruction manuals state to have the trailer level and stabilized before you run your slides out. I found the carpenter's level on the frame gave me the most accurrate set up readings.
Nothing sucks more than that moment during an argument when you realize you're wrong.
Ron3rd
Upland, CA USA
Mootpoint wrote: Most instruction manuals state to have the trailer level and stabilized before you run your slides out. I found the carpenter's level on the frame gave me the most accurrate set up readings.
That's what my manual says too; pull the slide out after the trailer is level. To the OP; you've received a lot of opinions on leveling methods above. Bottom line is they all work.
JoyceandSteve
Houston, Texas
I had thought that the slide would 'tilt' the TT. So I used a level on the floor, the stove top and on the front frame and found no difference. I do put the stabs down before running out the slide. Good thing I didn't bet on my 1st thoughts. FYI My slide incorperates the u-shaped dinnette and the jack knife sofa.
Happy Trails,
Steve & Joyce
2011 Chevrolet 2500 Z71 4X4
2013 Montana High Country 343 RL
1996 Celebrity 200 Boat
2000 Yamaha 1200 LTD Waverunner
2012 Ford Mustang GT (Mama's ride)
Vítejte na víkend doma a Steve Joyce
fosheek
Alabama
Lighten up folks. Can you walk around inside? Can you stay on the bed?
If yes-its close enough!
patinlouisiana
Baton Rouge, La
Just run out and get one of these!
