RV.Net Open Roads Forum: Tech Issues: Refrigerator interior light
 > Refrigerator interior light
altenbu
Williston, ND, USA
Posted: 04/14/12 06:11pm Link  |  Print  |  Notify Moderator
The Domestic refrigerator light always remains on, even when the door is closed. I changed the switch at the door, made no difference.
This is a : Domestic; Mod# RM3862; a 2 way operation, gas or electric
Where is my problem?
Thanks
Roger Altenburg
raltenbu@dia.net
Chris Bryant
DeLand, Florida, USA
Posted: 04/14/12 06:37pm Link  |  Print  |  Notify Moderator
Check the LAT switch- or Low Ambient Temperature. It keeps the light on for low ambient temp use.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
phillyg
Front Royal, VA
Posted: 04/14/12 06:43pm Link  |  Print  |  Notify Moderator
Did you see that the light was still on while you were sitting inside the fridge? Sorry, I couldn't resist asking.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
pulsar
Lewisville, NC
Posted: 04/14/12 06:52pm Link  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
ryanallie1
Magalia, Calif
Posted: 04/15/12 09:38am Link  |  Print  |  Notify Moderator
Hi All.
Yep, we sure would like to know, hoow you knnow that your Fridge Lights stays on while the door is closed.
On our Frige, the light ges on so fast you can't really tell. But by chance, if your Fridge Light does stay on, its probably your Light Switch has gone bad, or is wiored wrong.
A very simple fix, would be to put an On/Off Switch on the insidie of your RV Fridge. Or go to the troubel of fixing the Light Switch itslef.
Why don't you hook up a test lead, and then close the Fridge Door, and see if your drawing any power, with a cheap Test Light, that way you will be sure one way or the other.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Beaker
Brevard, NC
Posted: 04/15/12 03:48pm Link  |  Print  |  Notify Moderator
I used a camera with a timer on mine.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
altenbu
Williston, ND, USA
Posted: 04/15/12 03:57pm Link  |  Print  |  Notify Moderator
Thanks for suggesting I go in the ref, but when you push the switch on the ref that the door touches when the door closes, the light should go off, but it doesn't. Next comment on how do I go about correcting the problem.
2ndhom
Eugene, Oregon
Posted: 04/15/12 04:40pm Link  |  Print  |  Notify Moderator
YOU beat mt to it!!!! A job for little people!!
Antique Deere
LaGrange, IN USA
Posted: 04/16/12 08:59pm Link  |  Print  |  Notify Moderator
Turn off the low ambient switch located at the top of the freezer door area. Open the freezer door to gain access to the switch.
Bob T
altenbu
Williston, ND, USA
Posted: 04/18/12 08:34pm Link  |  Print  |  Notify Moderator
Thanks to the person who said to turn off the ambient switch.
