kidkasha
Ventura County
Planning on travelling close to wash canada border to pick someone up. Trying estimate milage and diesel cost, any good ideas? I was thinking about 3000 mi round trip in a 1999 Fleetwood Discovery getting roughly 8 mi to gallon. Will be towing back a suburban auto. Give me input Good or Bad
Diplomat Don
Moorpark, Ca
My Streets and Trips says you'll be travelling about 2500 miles. At an average of about $4.40 per gallon and 8mpg, you're looking at $1300.00 - $1400.00 in fuel. Missed the part about the Surban. I would figure $1500.00 in fuel.
Might be cheaper to fly up and drive the Suburban back if it's driveable.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
kidkasha
Ventura County
Would having four down make a big difference what is recommended?
othertonka
Stockton, CA
Are you going to tow the suburban 4 wheels down? If so are you sure that it is towable that way and if so does it have a towbar already attached? Just a coupl of extra things to consider.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
kjburns
Prescott, AZ
Do you have a trailer or is the Suburban setup for towing? If not, plan on some added time and expense.
2011 Winnebago Tour 42QD
ArcticDodge
Sammamish, WA
If the burb is driveable, I'd fly from LAX or Palm Springs up to Bellingham, WA on Allegiant Air.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
driveby
Vancouver BC Canada
ummm 1999 Burb is over your tow limit. Confirm whether you have a 3500 or 5000 # and I bet your Burb is closer to 6000 maybe more.
8MPG with a 1999 gas coach and that much toad is very very optimistic too.
Airfare will be cheaper! and definitely doable.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
kidkasha
Ventura County
What is Burb?
Mr.Mark
California/Tennessee
Kidkasha, a Burb is short for 'Suburban'. It will be rather expensive to outfit the Suburban with a base plate, etc., if it doesn't have it already. Do you already have a towbar on the back of the Discovery?
Driveby, I thought Fleetwood Discovery's were diesel powered.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
kidkasha
Ventura County
I have a towbar and a trailer that is 10 feet long and 8 feet wide with 2 wheels. Have never used the trailer, as the ramp does not accomadate my porsche and was going to have the ramp extended. My mh is a fleetwood discovery w/ 275 hp diesel, I know that I sound stupid as I am very new to the motor home community, but loving it.
edited 04/15/12 06:13pm by kidkasha *
