RV.Net Open Roads Forum: Class A Motorhomes: OMG PLEASE HELP!!!
 > OMG PLEASE HELP!!!
sundancer268
Charlevoix
Posted: 04/15/12 05:40am Link  |  Print  |  Notify Moderator
Diplomat Don wrote:
Make sure the area where the key slides into is lubricated with some grease (white lithium works best).
Do not use Lithium Grease, it has to low of an operating temperature for Disk Brakes. Use a synthetic disk brake lubricant. White lithium dates from the Drum Brake era and will just fail before its time in the high heat of the disk brake environment. Do not forget to grease both ends of the caliper and mount. I always used a sheet of sand paper to polish up the mounting points. Remember, the caliper has to slide freely or the inside pad will wear out a lot sooner than it should as it will be doing most of the work. Inspect your old pads and I will bet the inside pad is thinner than the outside pad due to the caliper not sliding freely. Any auto parts store will know what you need. Using a screw driver is a good idea to get the clearance you need.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
Gjac
Milford, CT
Posted: 04/15/12 06:19am Link  |  Print  |  Notify Moderator
I removed mine several years ago and had to use a wire brush and wire wheel on the removable parts to get the rust off prior to putting them back together.
big white whale
Edmonton--AB Canada
Posted: 04/15/12 08:50am Link  |  Print  |  Notify Moderator
Also make sure the bottom of the caliper is in it's place so the caliper is all the way down. This makes it easy to get the slide in.
supercub
Modesto CA
Posted: 04/15/12 09:29am Link  |  Print  |  Notify Moderator
Get a BIGGER Hammer !!
Just kidding, hope you get it figured out. Sounds like Diplomat Don had the right answer.
Brian
Diplomat Don
Moorpark, Ca
Posted: 04/15/12 10:50pm Link  |  Print  |  Notify Moderator
Sundance268.....Really......How did your post assist the OP in getting his brakes back together. Apparently, you don't know much about brakes. The section of the caliper I told the OP to lube doesn't require lubing on either side, just clean and reasemble. The white litium or any available grease, including hand lotion if that's all he had. is there just to assist in getting the retainer clip back in place.
If you're going to criticize, at least help the OP with something of value!
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
Brian in Michigan
S.E. Mi.
Posted: 04/16/12 06:07am Link  |  Print  |  Notify Moderator
I am defiantly no expert, but in the past when I've done disc's the orientation of the pads is important.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
crankshop1000
se michigan
Posted: 04/16/12 06:15am Link  |  Print  |  Notify Moderator
Please give the remainder of the brake job to someone capable of doing it right.Your family's safety is at risk.You are in over your head trying to save a couple of bucks.(Disclaimer-harsh but needs to be said.)
mowermech
Billings, MT
Posted: 04/16/12 06:23am Link  |  Print  |  Notify Moderator
As a retired mechanic with MANY drum and disc brake jobs in my past, I wholeheartedly agree! With something as critical to SAFETY as brakes, take it to a professional and get it done RIGHT the first time!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
thunderstruckhd
Ft.lauderdale and Key West,Florida
Posted: 04/16/12 08:11am Link  |  Print  |  Notify Moderator
EXACTLY !!!
Prevost H3-45 Featherlite Vantare
500HP Series 60 Detroit Diesel
Assorted trailers,toys and toads
And Zoie the Doberman.(01/26/01 - 07/23/11) R.I.P.
Malco
Farmingdale,NY
Posted: 04/16/12 08:52am Link  |  Print  |  Notify Moderator
Don't forget to take the cover off the fluid reservoir. Otherwise the calipers will close on their own.
Mal
