RV.Net Open Roads Forum: Tow Vehicles: ?aux fuel tank/ service guy @Ford
Search only in Tow Vehicles
 > ?aux fuel tank/ service guy @Ford
rmalik1
Pittsburgh,Pa.
Posted: 04/14/12 10:13pm Link  |  Print  |  Notify Moderator
Was at a Ford Dealer and was talking to the service guy about auxiliary fuel tanks I told him I was thinking about putting in one that dumped straight into the main fuel tank (not pumped in by computer like a transfer flow and not a transfer tank). Service guy said they had computer problems when using that type of aux tank?
Does that sound right?
Think OEM tank just knows how much diesel in it nothing else
Aux tank is made by Aluminum Tank Industries
2012 Cedar Creek 36RE w/ Level Up
B&W Turnover w/ 18k Companion Hitch
08 Ford 350 Lariat DW PSD Crew Cab Long Bed 4:30
Golden_HVAC
Fulltime, CA, USA
Posted: 04/15/12 01:44am Link  |  Print  |  Notify Moderator
Hi,
It used to be legal to have gravity flow into the main tank, but it has been against federal laws for many years now.
Ford must make sure that no more than 10 grams of fuel can evaporate from the fuel tank per 24 hours after 2005 model year, and even stopped installing a fuel return line, so that warm fuel was not recirculated back into the tank.
I don't think you will find a certified axillary fuel tank for a gasoline vehicle made after 2005. Yes they still make them for diesels.
Transfer Flow has all the Federal regulations on their website, you can look them up.
Fred.
Huntindog
phoenix arizona USA
Posted: 04/15/12 03:07am Link  |  Print  |  Notify Moderator
Golden_HVAC wrote:
Hi,
Fred.
This is not a problem for him. He has a diesel.
To the OP. I know that Ford has programming for the 2011-12s for this. I don't remember the details on it. I don't know about prior years.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
Farmer David
Mattoon, ILL.
Posted: 04/15/12 04:19am Link  |  Print  |  Notify Moderator
I have a RDS tank in a 2011 ford with gravity feed, has caused no problems I like the tank. But I had same tank in a 2007 Chevy before this truck and if I had the valve turned on for a long time with fuel in both tanks it would cause the fuel gauge to go nuts and read empty. It would go back to working right after I shut of valve from aux. tank.
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
lawnspecialties
Garner, NC
Posted: 04/15/12 06:41am Link  |  Print  |  Notify Moderator
I have a 90 gallon RDS tank from Northern Tool in my '11 F450. It was installed by my Ford dealer two months ago.
The only computer problems it has created is making things like "miles to empty" confused. Its gravity fed and works great. The gauge just keeps reading full until the big tank empties. I also have a small ball valve right where the fuel line exits the RDS tank so if I ever need to stop flow from the tank, its an easy turn of the handle.
2011 Ford F450 4X4
2011 Cyclone 370C
OldGreaser
South Texas
Posted: 04/15/12 06:50am Link  |  Print  |  Notify Moderator
I have a 65 gallon Titan replacement tank between the rails on my 2011 F350. Titan sent me a software patch to address miles to empty and said Ford could load it for me but I haven't had it done. I found that leaving the setting on 'not' towing makes the miles to empty somewhat reasonable. It hasn't been a problem at all. The only downside to the replacement tank is that it's a lot more money. You can do gravity feed for less than half of the $1500 I paid.
RGordon
Atoka, TN/North Ft Myers, FL
Posted: 04/15/12 08:21pm Link  |  Print  |  Notify Moderator
My 60 gallon RDS gravity tank will throw a check engine code if I continue to let the aux tank drain without gas gauge movement, especially if I turn engine on and off. It senses a fuel gauge failure. If I use the manual valve controlling how much I put in, it will work like a champ. One of the best things I have even done to my F350. It is an easy installation and only took me about 30 minutes. It only hurts when I have to fill it up!!!!
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/15/12 11:15pm Link  |  Print  |  Notify Moderator
A completely separate tank with a transfer pump would eliminate all of the computer and gauge problems. Fill both tanks, run the truck tank near empty, pull off the road, fill the truck tank from the aux tank and continue on your way.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
lawnspecialties
Garner, NC
Posted: 04/16/12 05:13am Link  |  Print  |  Notify Moderator
.....or a gravity fill setup with a ball valve in the line. Far cheaper.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 04/16/12 08:48am Link  |  Print  |  Notify Moderator
Don't they make true aux fuel tanks anymore? I installed a 100+ gal tank in my Dads 91 D-350 that even had a fuel gauge sender. Was set up like Fords aux tanks in that you switched from one tank to the other.
Was not a big deal to instal and you didn't need to stop to "transfer" fuel from one tank to the other. Never understood the whole transfer thing myself.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
