RV.Net Open Roads Forum: Dinghy Towing: pivot table
Search only in Dinghy Towing
 > pivot table
luvztheoutdoorz1
Lincoln, NE
Posted: 04/15/12 06:38am Link  |  Print  |  Notify Moderator
So, anyone have information on pivot tables. Do dollies need one? If there is not one on the dolly, what do you need to do to tow a small car?
Thanks-
Linda
Scout, 6 year old Husky/Shepherd
2011 Jayco Greyhawk 26DS
ronfisherman
SE Michigan
Posted: 04/15/12 07:29am Link  |  Print  |  Notify Moderator
Get a dolly with pivot plate or wheel steering. They work the best. Mine has wheel steering. 50,000 miles with no problems.
Kodiak Chassis Class C Forum
BillMFl
Posted: 04/22/12 06:54pm Link  |  Print  |  Notify Moderator
One of the advantages of a tow dolly is it works for multiple vehicles. We always have two or three front wheel drive cars and like the option of taking wichever one we want, without having to install tow gear on all of them. Mine pivots, tilts and has surge brakes. Easy on/off and no brake control system required. Only disadvantage is storing the dolly when not in use. On the road it tows so easy I forget its there.
Order is illusion. Chaos is reality. But right or wrong I'm still the captain.
willald
NC
Posted: 04/15/12 09:47am Link  |  Print  |  Notify Moderator
With a dolly, your choices are a pivot table, wheel steering (dolly wheels steer), or front wheels of towed vehicle do the steering.
Our dolly is the latter - no pivot table or wheel steering on the dolly, so towed vehicle's front wheels do the steering. Like with so many other things, each approach has its distinct advantages and disadvantages.
What I like about our approach is, it makes the dolly (ACME EZE tow dolly) much simpler and lighter not having a pivot table or steering wheels - ours only weighs around 400 lbs making it pretty easy to move around by hand when you need to. It also can handle up to a 5,000 lb vehicle, and is low enough I can put it almost completely under the MH when parked, so its not in the way.
Downside is, I have to leave a key in ignition in 'Accessory' position on towed vehicle, to keep steering column unlocked.
I like the idea of a dolly with wheels that do the steering for you. Only problem is, those dollies are so expensive, you're approaching the same cost it'd be to set your vehicle up for 4 down towing.
Will & Angela
2 children that love camping, Stephen & Allison
2012 FR Georgetown 351DS on F53 (V10) Chassis
Our Rig
luvztheoutdoorz1
Lincoln, NE
Posted: 04/15/12 10:04am Link  |  Print  |  Notify Moderator
Thanks. That helps me to understand the differences. I think I also have the same type that you do.
tahiti16
Camarillo, CA
Posted: 04/17/12 12:12am Link  |  Print  |  Notify Moderator
I have one that uses the pivot, very low maintenance, just a squirt of grease in 2 zirks once a year and check the bolts. Ours also tilts to make the angle better for loading, good thing I am towing a BMW 323 so pretty low.
I like that I can lock the car and not worry about leaving a key in it.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
BillMFl
Posted: 04/25/12 11:02am Link  |  Print  |  Notify Moderator
luvztheoutdoorz1 wrote:
"The carrying pan steers for your car by swiveling smoothly on polyethylene pads which are maintenance free. "
Does this mean that it pivots?
Yup. And it tracks very nicely. The only way I know its there is the rear view camera.
luvztheoutdoorz1
Lincoln, NE
Posted: 04/23/12 11:47am Link  |  Print  |  Notify Moderator
 > pivot table
