RV.Net Open Roads Forum: looking at dually need help with tow ratings
Search only in Tow Vehicles
 > looking at dually need help with tow ratings
bironacad
Ontario
Posted: 04/15/12 07:22am Link  |  Print  |  Notify Moderator
There is a used truck for sale and I can't seem to find it's numbers online.
The Truck is:
2008 Dodge Ram Resistol Laramie Mega Cab 3500 4x4 DRW
Anyone have the numbers:
gvwr gcvwr
I don't now the gear ratio.
Thanks
Redwood 36RL triple slide
12,700 lbs
Truck:
03/2500 HD Laramie/5.9 CTD SO/4x4 limited slip rear end/quad/long box/extra leafs/Trailer Package/automatic/ 4" exhaust/Prodigy brake controller/EGT/PYRO & Boost gauges/Smarty JR tuner
NewsW
US
Posted: 04/15/12 07:30am Link  |  Print  |  Notify Moderator
You have to have the VIN and see what it is speced for, assuming it is not modded.
bironacad
Ontario
Posted: 04/15/12 07:35am Link  |  Print  |  Notify Moderator
Ya but the numbers off the door would be nice, I think the gcvwr is in the glove box. I am not there though, lol. Anyone out there with a similar vehicle?
chuggs
Are you able to look at the truck?
If yes, lift the hood...and look up. There is a decal fixed to the underside of the hood with build data... That will tell you the axle ratio.
Then...look in the glovebox for an owners manual.
GVWR, GAWR...should be on a decal on the drivers door pillar.
donn0128
Pronounced Ore-gun
Posted: 04/15/12 07:37am Link  |  Print  |  Notify Moderator
Look on the drivers door post for the numbers. Inside the glove compartment for the build sheet. Is the cowboy hat with the truck?
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
LarryJM
NoVa
Posted: 04/15/12 07:47am Link  |  Print  |  Notify Moderator
The Truck is:
gvwr gcvwr
Thanks
You don't have enough information for anyone to even give a SWAG or probably even a WAG. The rear gearing can be a MAJOR factor in the GCWR not to mention the engine.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
bironacad
Ontario
Posted: 04/15/12 07:51am Link  |  Print  |  Notify Moderator
LarryJM wrote:
The Truck is:
gvwr gcvwr
Thanks
Larry
It is a diesel and it is 200kms away lets go with a 3.73 rear end dually thanks. If I could lift the hood I would have I know it is first thing in the morning guys but really, lol.
donn0128
Pronounced Ore-gun
Posted: 04/15/12 08:04am Link  |  Print  |  Notify Moderator
If I remember correctly the GCWR is right at 21K. The problem with mega cabs has always been ratings. they are rated lower than the quad cabs because of the extra weight of the cab and possibly a bit softer springs. There are people here towing large fivers with the mega cab, so don't get too worried about that.
I am sending you a PM.
chuggs
Posted: 04/15/12 08:19am Link  |  Print  |  Notify Moderator
Deleted
* This post was edited 04/15/12 08:48am by chuggs *
chuggs
Posted: 04/15/12 08:29am Link  |  Print  |  Notify Moderator
Online sales brochure
There's a table with capacities in this sales brochure...you can plug in your assumptions...and come up with an approximate value to go on for now.
Best we can probably do...
Based on 3.73 axle ratio...
Automatic
Payload 2770
GCWR 21000
Max Trailer weight 13,500
Manual
Payload 2700
GCWR 21000
Max Trailer weight 13,400
Trailer weight based on 150# driver....subtract, options, cargo, passengers....and if your like me...a bit more for the driver...I haven't weighed 150 # since I was a Freshman in college....
* This post was edited 04/15/12 08:47am by chuggs *
