RV.Net Open Roads Forum: Fifth-Wheels: Leveling the 5er.......
 > Leveling the 5er.......
greende
Syracuse,NY
Posted: 04/15/12 04:50pm Link  |  Print  |  Notify Moderator
Boards. Some of the State Parks we go to can require 3-4" to get the rig level.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
32dgrz
Iowa
Posted: 04/15/12 05:39pm Link  |  Print  |  Notify Moderator
This is what I use. Home made. I found the instructions on this forum
RickSo
Alberta,Canada
Posted: 04/15/12 06:32pm Link  |  Print  |  Notify Moderator
I used exactly the same set up on my last 5er. The air levelers worked very well...still use the Rotochoks. Now, on the new rig I also use the auto leveling system.
Rick
2012 Excel W41GKE Wild Cargo Toy Hauler
2008 Freightliner Sport Chassis RHA114
2010 BMW K1300GT
2008 BMW R1200GS
Weazletoe
Idaho
Posted: 04/15/12 09:14pm Link  |  Print  |  Notify Moderator
I took an eight food 2x6 and cut 30", 24", 18", and 12" pieces, all with a 45* angle on the edge, stacked them and screwed them together. Now, I have a $2.00 leveling ramp, up to 6" in height. Every 1 1/2 inch in height, I have a nice platform 6" long that accomodates the tire just perfectly.
For the landing gear, I cut nine pieces of 2x4, 9" long and screwed them together. I cut four more pieces the same length and attached two on the bottom of the nine, and two one the top of it. That gave me a nice 9x9x6 1/2 block to put under each leg.
TV- 1990 Chevy 3500, 454, 3 speed, 4x4
5er - 1991 Prowler, 25ft
jetenbu
Southeast Texas
Posted: 04/16/12 08:37am Link  |  Print  |  Notify Moderator
I sure would like to make these myself. I can not seem to find the instructions on this forum. Do you have a link I can use?
I appreciate your help....
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
bpounds
Whittier CA
Posted: 04/16/12 08:53am Link  |  Print  |  Notify Moderator
Those are nicely made. But I figure that by the time I dig out an air compressor, hose, and plug it in to fill the bags, not to mention the time it will take to fill them, I will already be leveled on blocks, unhitched, and eating a sandwich.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
RickSo
Alberta,Canada
Posted: 04/16/12 11:34am Link  |  Print  |  Notify Moderator
I used a small rechargeable compressor that stayed with the air leveller's...really didn't take that long. The new auto hydraulic auto levelling system is one of the best options on the new unit.
I bought my air leveler's from the company that originally made them...I even have three extra one's new that a person asked me to get but never picked up. Here is a DIY link http://www.youtube.com/watch?v=x19Wsx2OSz8
* This post was edited 04/16/12 12:36pm by RickSo *
laknox
Arizona
Posted: 04/16/12 01:13pm Link  |  Print  |  Notify Moderator
jwduke wrote:
What does everybody use to level their 5er? Boards or ?????
I have a set of the "lego" blocks that I use, but also carry a number of boards. At my favorite bookdock site, I carry my boards that I normally park on in storage (two, 4' 2x6 redwood boards screwed together) and use one of them on the downhill side, which levels me up almost perfectly. On a fairly level site, I'll use my lego blocks under my rear stabilizers instead of boards. :-)
Lyle
1936 John Deere Model A
JEBar
Willow Springs, NC
Posted: 04/16/12 01:36pm Link  |  Print  |  Notify Moderator
over the years we've tried most everything mentioned .... for us the plastic lego blocks broke when used on gravel and sank when used on sand/dirt .... the airbags leaked and we never could get the camper stabilized to where the motion from walking around wasn't more than we found acceptable .... assorted thicknesses of ply board, 1x8's, 2x8's cut so they would fit between the tires worked best and served us well for a long time .... a year ago we had a Bigfoot leveling system installed and my only question is I can't figure out why we waited so long
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
bpounds
Whittier CA
Posted: 04/16/12 03:05pm Link  |  Print  |  Notify Moderator
As far as wooden blocks go, I've never needed to carry 1x stock (3/4") just the 2x size (1-1/2"). When I've needed less than 1-1/2", I just put a block under one tire, and nothing under the other. The net is about a 3/4" lift. Or one block under one tire, two blocks under the other. Never needed to be more level than that. With experience reading the level, you will hit the block combo the first time, almost every time.
