jwduke
Ice Cream Capital of the World (Le Mars), Ia.
What does everybody use to level their 5er? Boards or ?????
'04 Dodge 2500 QC 4x4 w/CTD
'03 Hitchhiker II 31RLBG
ReneeG
Meridian, Idaho
We use those hard plastic linking blocks. Keep two sets on hand because we use them under our rear landing gear too.
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
jwduke
Do the plastic leveling blocks work good? I have hear a heavy 5er will crush them.....
hmknightnc
Wilmington, NC
2x8 boards. Get a 16 foot length board cut it into 5', 5'4" and 5'8" lengths. Cut 45 degree angle on one end of each board so you can stack and drive on as needed. I've always been able to get level side to side with no more than these 3 boards
bpounds
Whittier CA
Yep, boards. But I like to cut them into pieces about 12"-16" long. Longer boards that lift both axles may have to span high spot or divots, that make them unstable. They can even flip up as you back onto them and smack the trailer skirting. Plus I only have to backup an additional foot or so to be on them. To each their own on that.
The plastic probably won't crush, but they will break if you don't place them on flat solid ground. Especially in cold weather. I don't feel I need them, but seems to me that they work well enough, are light, and easier to keep clean.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
dannytas
Pioneer, CA
ReneeG wrote: We use those hard plastic linking blocks. Keep two sets on hand because we use them under our rear landing gear too.
DITTO on the plastic. I like the versatility of them and they store well, too!
'12 Keystone Cougar 297RKSWE
'03 Dodge 3500 QC 4X4 Long bed Dually
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
rasteck
Northern California/East Bay
dannytas wrote: ReneeG wrote: We use those hard plastic linking blocks. Keep two sets on hand because we use them under our rear landing gear too.
x3
I use them to level the picnic table too, if necessary.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
brirene
midwest
jwduke wrote: Do the plastic leveling blocks work good? I have hear a heavy 5er will crush them.....
Haven't had any problem like that. Couple might not be as pretty as brand new, but none are broken or crushed.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
Cool Canuck
Winnipeg, MB, Canada
My boards are small enough to fit between the wheels. Some a little shorter than others so I can stack where need be. I never need to move more that a couple of feet to level the fiver. The graduated level on the nose indicates with relative accuracy how many inches I need to raise it.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
larry barnhart
wenatchee. wa usa
If the ground gives the plastic blocks can explode and come back at you. I use them but have the same size in 3/4 plywood.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
