RV.Net Open Roads Forum: General RVing Issues: Suburban anode rod
 > Suburban anode rod
tessa25
Colorado
Posted: 04/15/12 10:48am Link  |  Print  |  Notify Moderator
The threads where the anode rod goes on my Suburban water heater aren't all neat and pretty. When I try to screw in a new Suburban anode rod it only goes in half way. Is this normal? If not, is there something I can use (toothbrush alone did not work) to clean up the threads so the anode rod will go in further?
Thanks!
Palomino Gazelle G150
coolbreeze01
Redding, Ca
Posted: 04/15/12 10:55am Link  |  Print  |  Notify Moderator
They just don't thread in all the way. I use a little thread tape on mine, just 'cause.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
downtheroad
Pacific Northwest
Posted: 04/15/12 10:56am Link  |  Print  |  Notify Moderator
Yes, that's normal...the the threads are tapered. Wrap it a couple of times with Teflon Tape and screw it in. If it doesn't leak you are good to go.
Three trailers with a Suburban WH and none of the anode rods screwed in 'all the way'.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
vladen
Louisiana
Posted: 04/15/12 11:08am Link  |  Print  |  Notify Moderator
I suppose you could run a pipe thread tap in to clean it out if you stop when your supposed to.
Vlad's busy workings
All hope is gone
tessa25
Colorado
Posted: 04/15/12 11:16am Link  |  Print  |  Notify Moderator
Thank you!
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/15/12 11:25am Link  |  Print  |  Notify Moderator
The threads are pipe thread which are tapered. They are designed not to go all the way in.
The anode needs to contact the metal of the tank. Go easy on the Teflon tape or use pipe dope.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
