RV.Net Open Roads Forum: Solar question, what happens when you don't need the power
 > Solar question, what happens when you don't need the power
doughere
Mooresville NC
Posted: 04/15/12 12:10pm Link  |  Print  |  Notify Moderator
I'm thinking of installing about 200 watts of solar on our 5er; We have a 300 AmpHour battery, so this would pretty much supply our total needs under almost all conditions. BUT: the 5er sits in the driveway unused 6 to 8 months a year. What is the effect/problem/danger of leaving the panels uncovered if there is no place to use the power??
Thanks,
Doug
3 tons
CA.
Posted: 04/15/12 12:21pm Link  |  Print  |  Notify Moderator
No affect, without current flow its like having an open circuit.
mena661
Posted: 04/15/12 01:47pm Link  |  Print  |  Notify Moderator
jauguston wrote:
The solar controller limits the panel output when the batteries are charged.
X2
Trojan L16 6V's 740 Amp-hours
vladen
Louisiana
Posted: 04/15/12 12:29pm Link  |  Print  |  Notify Moderator
Well the panels do degrade over time and gradually lose output so If they wernt actually being of purpose Id get em out of the sun.
Vlad's busy workings
All hope is gone
jauguston
Bellingham, WA
Posted: 04/15/12 12:37pm Link  |  Print  |  Notify Moderator
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Almot
Vancouver BC
Posted: 04/15/12 05:30pm Link  |  Print  |  Notify Moderator
Guys are correct in that uncovered solar panel won't hurt the battery. But there are other things to consider:
If you cover the panel, you extend its life but are left without maintenance charging or trickle charging. Battery is self-discharging with time, and you shouldn't let the charge drop below 50%. This is not a problem if your batteries are AGM, it should still have enough charge left after 8 months if ambient temps aren't too high. But a flooded type battery will self-discharge to 50% in less than 4 months. Plus, there are often parasitic loads like standby current from clock radio etc, if batteries are not completely disconnected from all the loads.
If you have 120V maintainer while in storage, you don't need to worry about self-discharge and parasitic loads.
Golden_HVAC
Fulltime, CA, USA
Posted: 04/17/12 05:55pm Link  |  Print  |  Notify Moderator
Hi,
My 415 watt solar system has been hooked up to the batteries since 1999, and to date the first set of batteries where replaced and given to a friend because they still where in great shape. THe second set is only about 6 years old now, and are working great.
The regulator stops charging when the voltage reaches the cut off point, and might start charging around 4-5 PM if required, or might stay off from noon to the next morning.
Fred.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 04/17/12 10:17pm Link  |  Print  |  Notify Moderator
My batteries get charged to 14.5 volts everyday and that is using just the 2x80 watt panels that hang on the end of my carport, the others are under the roof and covered with a 1/4 in of dust so I don't think they would be putting out much power, been that way from day 1 and still have the same 8 batteries. Just my thoughts.
1998 34' Newmar Mountain Aire,210 Cummins Puller, 542 Allison 4 speed, BD Performance Exhaust Brake, BD Torque Convertor, Hendrickson Air suspension, 4 wheel disc brakes. 4-120 Watt 2-80 Watt Kyocera panels 8-T105s Toad 2003 VW Jetta TDI.
Almot
Vancouver BC
Posted: 04/18/12 06:52pm Link  |  Print  |  Notify Moderator
Golden, a quick question: what controller do you use? With 415W panel, even when it's flat-mounted, there can be 30-35A after controller in summer.
