RV.Net Open Roads Forum: how do you mount your Porta-Bote on your 5th
 > how do you mount your Porta-Bote on your 5th
Ed9824v
Agua Dulce, Calif. 70 mi S.E. of Los Angeles
Posted: 04/15/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I picked up a 12 foot Porta bote and want to bring it along attached to the 5th wheel. I here of the side mount which I am not found of, the top or the belly what have you all done
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
lovetotow
ontario
Posted: 04/15/12 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
my father in law carried his 12 ft jon boat on a hitch carier on the back of his 5er, you just have to be aware of low bridges
Dale & Lynda
2001 285J Prowler 5th wheel
2005 Chev Silverado 2500HD 4x4
wildmanbaker
Kennewick, Washington
Posted: 04/15/12 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
You will probably get more answers if you ask this in the "Fifth Wheels" forum.
Wildman
Ed9824v
Posted: 04/15/12 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I had done that. Oh well
amandasgramma
Oregon
Posted: 04/15/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
My DH bought special clamps from the Porta-boat dealer. He attached them to the side of our 5er --- The boat clamps to the side on those clamps. Ours is a 12 footer, too. They cost almost $200. but they worked better than anything he could dream up.
Lantley
Ellicott City, Maryland
Posted: 04/15/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I carry my 14' Porta Bote beneath the trailer using ratchet straps.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
Ed9824v
Posted: 04/15/12 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
That would be a simple solution, I will look into it
Jim & Betty
Brandon, South Dakota
Posted: 04/15/12 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe a wrack on the tow vehicle, you will need that to take the boat to water. Mine is on my towed ,Jeep,
JimR
Lantley
Posted: 04/16/12 04:19am Link  |  Quote  |  Print  |  Notify Moderator
Underneath works well bote is out of the way. I carry it there the entire camping season. getting underneath the rig and crawling around to store or remove the bote can be a pain, but I somehow manage to get through it.
BillsMax
North Carolina
Posted: 04/16/12 05:17am Link  |  Quote  |  Print  |  Notify Moderator
If it will fit, underneath is the perfect place to carry it. My previous RV was a 38' Jayco 5th wheel. I mounted the side brackets underneath the 5'er towards the front. The front of the 12ft boat stuck out about 4 inches on the front end. Made it very easy to unlock the brackets and slide the boat out. I would always lay my carpet under the 5'er to slide the boat in position to put it in brackets or take it out. If you go this route, be sure to put locks on the bracket.
I now have a coach and carrying the folded boat in my long bed pickup toad, with the boat extending over the tailgate.
Have fun, you'll love the Porta-bote. By the way, you can find lots of mods for you boat in the Porta-bote forums. I've mounted a hard prow for trolling motor and anchor hoist. Also added swivel bass seat on my back seat.
2008 Monaco Signature
Pushed by White 2005 chevy 2500 crew cab Lb 4x4 Duramax/allison with 12 ft Porta-Bote in the truck bed.
