kennyd63
Minooka, Illinois
Ok in my 2003 25 J Mallard the previous owner replaced the Dometic frige with a Home Depot 17CF frige. I supposted this is Do to a recall back when. He decide to replace it with the Magic chef brand. OK it does works and it fits in place just fine!!My concern, is this safe to do. or do we need to make sure is a TT frige?
Thanks in advance!!!
Kennedy,
2005 National Sea Breeze LX 8321
2010 Forest River Salem 403FB-Destination Trailer
2009 F150 4X4 Crew Cab
2006 HD Heritage Softtail
1999 Sweetwater Challenger 30hp (Pontoon)
Old-Biscuit
Across the USA
I take it the Magic Chief fridge is an 110V AC only.......as in a residential fridge.
Many RV absorption fridges have been replaced with residential fridges.
Only down side........have to have external power source (Power receptacle/generator). No using propane.
Wills250psd
walnutcove NC
I have saw a few like that and they work great. Only you cant use the LP but I never have in all these years.Dont worry or spend the money just go camping.Good luck
skipnchar
Topeka or somewhere else
The main DOWN side of using a 120 volt AC compressor driven fridge is that you can't use it while going down the road or when dry camping. As long as you plan on camping close to home in RV Parks or campgrounds with electric hook ups the fridge will be just fine. It will also weigh about four times as much as a standard RV fridge so it will take a big bite out of the cargo carrying capacity of your trailer.
Good luck / Skip
seekertom
home
skipnchar, my dometic died today and in researching house friges i find 9 cu ft-ers weighing in at about 100 lbs. don't think my dometic is quarter of that.
st
LarryJM
NoVa
seekertom wrote: skipnchar, my dometic died today and in researching house friges i find 9 cu ft-ers weighing in at about 100 lbs. don't think my dometic is quarter of that.
st
Ah and now some FACTS ...
From the CW web site for the 10cu ft Dometic New Dimensions NDR1062
Tech Specs
Weight: 152 lbs.
Dimensions:
Overall: 59-15/16"H x 23-11/16"W x 24"D
Recess: Please call
Warranty: Mfr. two year limited warranty.
Manufacturer: Dometic Corp
Mfg Part #: NDM1062RBIM
From the Frigidaire website:
Frigidaire 16.5 Cu. Ft. Top Freezer Refrigerator
Model: FFHT1715LB
Shipping wt - not actual refer wt. is only 190lbs.
and
Frigidaire 9.9 Cu. Ft. Top Freezer Apartment-Size Refrigerator
Model: FFHT10F2LB
Shipping wt - 154lbs
Moral of this story is to never believe for a fact what might be posted here since there is a lot of misinformation out there and outlandish claims/statements.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
BurbMan
Louisville, KY
Other point is to be sure that it is secured properly for travel. An RV fridge mounts in a recessed cabinet that holds it in place. Most residential fridges are free-standing, so be sure that it is secured propoerly for travel, ie bolted to the floor and/or wall. Also RV frudges have door locks to keep them from opening enroute. You can use bungee cords or similar to keep the door on the residential fridge closed.
seekertom
home
larryjm... more facts...
Manufacturer:
Frigidaire
Manufacturer Model:
FFPT10F3MB
Style:
Top-Mount
Capacity - Total (CuFt):
9.9
Defrost Type:
Frost Free
Capacity - Refrigerator (CuFt):
7.6
Capacity - Freezer (CuFt):
2.3
Energy Saving:
Energy Star
Shelves (#):
3
Adjustable Shelves:
Yes
Slide-Out Shelves:
2
Shelf Construction:
Glass
Door Bins (#):
2
Temperature Control Type:
Analog
Temperature Settings:
7
Humidity-Controlled Crisper:
Yes
Color:
Black
Dimensions
Unboxed
Width: 23.4 in
Height: 59.9 in
Depth: 26.0 in
Weight: 132 lbs
from the store. also, is energy star compliant, 389kwh/yr (wish i knew the amps)
there's big differences in size and weight between std house fridge, apt sized and mini's. 359 vs 1300. hmmmm what's in MY wallet?
as for mounting, intend to put back where current one is, up on the padestal, and yes, firmly attached, and yes some additional door catches, only light weight food on glass shelves etc.
sure, need to handle some concessions, but if i had the cash, i wouldn't be driving a 24 yr old either.
am
