RV.Net Open Roads Forum: Travel Trailers: bearing buddies
 > bearing buddies
v2k1966
Jasper
Posted: 04/15/12 06:07pm Link  |  Print  |  Notify Moderator
For the people that have bearing buddies, what kind of grease do you use? And how often do you pump it in?
Thank You
Chuck&Gail
In the Colorado Mountains
Posted: 04/15/12 06:15pm Link  |  Print  |  Notify Moderator
Mobil 1 synthetic.
I add more when built in indicator on Bearing Buddies indicates more is needed. It is rare.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
coolbreeze01
Redding, Ca
Posted: 04/15/12 06:21pm Link  |  Print  |  Notify Moderator
Chevron once a year in my EZ-Lubes.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
ChinoBob
Chino, Ca.
Posted: 04/15/12 06:24pm Link  |  Print  |  Notify Moderator
Depending if travel trailer or boat trailer.Using both, I echo Chuck and Gail and Mobil 1. However I can't remember the last time used, although checked every trip. Boat trailer, I use a heavy marine grease and grease often. I run them fuller than most but rather have the sealing. Also, if a boat trailer, never back it right into the water after a long trip. Let is cool, even a few minutes helps. I learned the hard way... Travel safely and have fun!
skipnchar
Topeka or somewhere else
Posted: 04/15/12 06:31pm Link  |  Print  |  Notify Moderator
I"d be VERY careful about putting too much grease in a bearing buddy since the grease can very easily lube your brake shoes and make your trailer brakes useless. That's why you almost never find them in use on a trailer with brakes.
Good luck / Skip
MudChucker
Niverville Manitoba
Are these bearing buddies EZ lubes ?
They are not the same.
EZ lube by dexter requires a lithium complex grease as per the spec.
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
301TBS
Ontario, Canada
Posted: 04/15/12 07:05pm Link  |  Print  |  Notify Moderator
Dexter easy lubes on tt's and fifth wheels expell old grease out the wheel end, not onto the brakes. Bearing buddies used on boat trailers are different and can expell old grease past the seals. Read the instructions before you attempt. Bearing buddies are often added later on trailers and work fine if you lube them properly. Use google, it knows EVERYTHING.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
v2k1966
Jasper
Posted: 04/15/12 09:14pm Link  |  Print  |  Notify Moderator
I beleive it says Lippert on the black rubber cap of the bearing. Would that make it an EZ lube?
MudChucker
Niverville Manitoba
Posted: 04/16/12 04:26am Link  |  Print  |  Notify Moderator
Assuming this is your axle,
Lippert manual
MudChucker
Niverville Manitoba
Posted: 04/16/12 04:29am Link  |  Print  |  Notify Moderator
BTW
This is a bearing buddy
Bearing buddy webby
 > bearing buddies
