bpounds
Whittier CA
How much did you use? How big is your FW tank?
I use 1/4 cup per 15 gals. That's more than many people use, but it doesn't hurt anything and I know it is effective.
I pour it right down the gravity fill, immediately followed up with the water hose.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
rattleNsmoke
Western Conn.
I douched mine yesterday as well......Prolly got some into the h\w tank too. That baking soda tip is gonna be helpfull. Thanks.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Far-N-Sweet
Liberty Twp, Ohio
Didn't even consider the hot water heater. Thought buy running the pump with the valves open both Hot and cold at the same time it would get it. Now that I think about it it does seems it is more the Hot water than the cold.
As for how much embarrassed to say but tank is 85 gal and I used about 2 gal of bleach. Since the low drain points were open and I was not sure instead of 1 gal I added the second to be sure. Probably where I went wrong.
Far-N-Sweet
bpounds
Whittier CA
Okay, yeah, that IS a lot!
Still, don't think you need to do anything but drain it, and run enough through to clear the HWH. That is strong enough to kill your lawn, but I guess it is too late for that info.
christopherglenn
a little over an hour from Yosemite
I don't put that much in a 600 gallon hot tub....
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
dubdub07
Colorado Springs
Vet Man wrote: If your flushing with city water the smell may not go away.
Unless you are lucky enough to live in Colorado where we get bottled quality water right out of the tap!
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
RAS43
Littleton,CO
Weazletoe wrote: Would it be a good idea to mix some vinegar with that bakng soda? LOL
I have used both but not together. IMO the baking soda worked better without any after taste.
dannytas
Pioneer, CA
Alpenliter wrote: RAS43 wrote: Mix about a quarter cup of baking soda into a couple of gallons of water and add it to the tank. Then fill the tank and run the water thru the system and let sit for a few hours. Then flush it out and you should be good.
X2 Welcome to the Forum. Don't sweat it, we've been there too.
X3...been there, done that! The nice thing about it, you'll only do THAT once!!!
'12 Keystone Cougar 297RKSWE
'03 Dodge 3500 QC 4X4 Long bed Dually
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
jdiffend
Denver, CO
Wow, 2 gallons of bleach? If left very long it could damage something. Bleach is nasty stuff.
It doesn't take a lot of bleach to sterilize water. Clorox only talks about 8 drops (clear water) to 16 drops (cloudy water) per gallon to make water safe to drink.
For my 60 ish gallon tank that's 1056 drops with the higher dose.
20 drops is supposed to be a milliliter.
That means for 60 gallons I need 52.8 milliliters or .22317255 cups.
That's only 1/4 cup.
I know I've read you should use 1/4 cup per 15 gallons on several sites; that's 4 times the concentration Clorox lists as required to make even cloudy water safe.
It sounds a little overkill to me for regular maintenance, but it should certainly do the job.
Just be sure to let it sit in the system for at least 30 minutes.
bpounds
Whittier CA
jdiffend wrote: Wow, 2 gallons of bleach? If left very long it could damage something. Bleach is nasty stuff.
The Clorox recommendation is if you are going to drink the treated water. I don't drink it, I run it through the system and then drain it. I would not recommend consuming a 1/4 cup per 15 gallon concentration.
