RV.Net Open Roads Forum: Class A Motorhomes: I Bagged a "Turkey"
 > I Bagged a "Turkey"
Page of 5
Mike & Fran
West Texas
Posted: 04/16/12 06:34am Link  |  Print  |  Notify Moderator
Wild turkeys fly very well. They resemble a quail in flight. They are very dangerous out here in west texas while riding your m/cycle. When one comes across the road, look out because all of them will follow!!
Chrisatthebeach
The beautiful low country of South Carolina
Posted: 04/16/12 07:22am Link  |  Print  |  Notify Moderator
I would have taken me longer to clean out my pants than it will take to clean out the motorhome.
Go buy lottery tickets while this run of good luck is with you.
I am glad both of you are safe.
Chris
Chris & Dianne plus two boys, both of them are Eagle Scouts.
Jayco Designer 3110
F250 PSD 4x4 Crew Cab
W4MBG
Williamsburg, VA
Posted: 04/16/12 08:11am Link  |  Print  |  Notify Moderator
"As God is my witness, I thought turkeys could fly."
the whole room here said that quote after i read the first paragraph. yes, we are old...
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
msmith1199
Central, CA
Posted: 04/16/12 08:44am Link  |  Print  |  Notify Moderator
Mr.Mark wrote:
Wow, amazing! Glad that the both of you weren't hurt!
There is another RV.net member that had this happen to his class-A and he posted pics too.
Our exit door will not open until the air brakes are released as we have a seal around the door that fills with air. I guess we could toss it out a window!
MM.
There's another discussion, your exit door won't open until the brakes are released? Is that safe? I don't think I'd want a door that doesn't open when I need it to open without having to rely on something like the brakes being released.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
JTHarley
Northeast, Michigan, USA
Posted: 04/16/12 11:57am Link  |  Print  |  Notify Moderator
MM.
Having gone thru this I too would not like a door you can't open. Mine locks automatically but you can unlock it by the button even while your moving.
Jim , MJ & Spirit of Sambuca Bear
"He's one big Newfie"
Dynamax Ultra 450UL
450 MBE
Jeep Sahara Toad
Bonefish
Midland, TX
Posted: 04/16/12 12:16pm Link  |  Print  |  Notify Moderator
So did you smoke, bake or deep fry him?
You are lucky it wasn't a buzzard! Hit one of those once but was lucky it didn't come through except for the smell.
Bonefish
John&Joey
Some Location
Posted: 04/16/12 12:51pm Link  |  Print  |  Notify Moderator
Came up the Natchez Parkway Trail two days ago and a turkey tried to run right into the side of the MH. Not the smartest birds around I guess.
Alphamonk
North Carolina
Posted: 04/16/12 01:36pm Link  |  Print  |  Notify Moderator
I read once that Benjamin Franklin wanted to make them the National bird instead of the Eagle! Glad that didn't work out.
MrWizard
Traveling
Posted: 04/16/12 01:48pm Link  |  Print  |  Notify Moderator
yes we are All getting old
its "farmed" turkeys that have clipped wings
Wild Turkeys do fly
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
barlow46
Edgewater, FL
Posted: 04/16/12 04:23pm Link  |  Print  |  Notify Moderator
MM.
Mark,
Have you tried opening your door with the air brake off and on. I think I have the same system that you do and I can open mine with both the air brake on and off...makes no difference. The seal just expands against the joint but I don't believe it keeps the door from opening unless something changed in the design between 2005 and 2008 in the Dynasty.
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
Page of 5
