RV.Net Open Roads Forum: Dometic 2652 - Am I missing a shelf?
 > Dometic 2652 - Am I missing a shelf?
bob213
Fresno, CA
Posted: 04/15/12 07:48pm Link  |  Print  |  Notify Moderator
Just got a new Surveyor SV264. Looked at the refrig in the inspection...it worked.
Now we had a 2652 in our last trailer but can't seem to remember. (wife only opens refrig to get her milk out, so she's not much help). Anyways, this refrig has the 2 bins on the bottom with a shelf just above them covered by a thin white plastic. Next up is a deep shelf with the hole cut out for the milk jug. Above that is the skinny wire shelf by the fins. Should there be one more shelf? I looked in the manual but in parts section it only mentions "door shelves". Would someone please look at theirs and tell me if I dreaming or I'm missing a shelf.
Thanks....
Bob
Old-Biscuit
Across the USA
Posted: 04/15/12 07:56pm Link  |  Print  |  Notify Moderator
Dometic 2652 Parts list
bob213
Fresno, CA
Posted: 04/15/12 08:13pm Link  |  Print  |  Notify Moderator
Thanks Old-Biscuit. My manual doesn't contain this parts list. I am missing a shelf. Should I contact Dometic direct?
Bob
Old-Biscuit
Across the USA
Posted: 04/15/12 08:28pm Link  |  Print  |  Notify Moderator
Bob
Dealer close.......download the parts manual and show them "Hey missing a shelf"
Dealer not close....call Dometic with serial number and ask for the missing shelf.
dqdick
Council Grove, KS
Posted: 04/15/12 08:37pm Link  |  Print  |  Notify Moderator
I wasn't happy with the number of shelves and so ordered four more door shelves and two more freezer shelves. Took two months and four deliveries of the wrong shelves to get the freezer shelves. Good luck.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
dougrainer
Carrolton, Texas
Posted: 04/16/12 06:00am Link  |  Print  |  Notify Moderator
Just because the Parts breakdown SHOWS more shelves does not mean they come with all the shelves. Contac Dometic and ask how many shelves they supply at build. Doug
dougrainer
Carrolton, Texas
Posted: 04/16/12 09:22am Link  |  Print  |  Notify Moderator
Dometic will require the Model and the Serial number and most important, the PRODUCT number to give you an answer. If you post that Product number, I can find the answer. Doug
Ron3rd
Upland, CA USA
Posted: 04/16/12 06:35am Link  |  Print  |  Notify Moderator
bob, you've got the same number of shelves that came with my Dometic fridge.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
12thgenusa
Lakewood, Colorado
Posted: 04/16/12 09:03am Link  |  Print  |  Notify Moderator
Interesting. Our Cougar also has the DM2652. When we got it home after we bought it in 2009, the DW said "we are missing a shelf". We had the one with the large cut out and the small one that goes on top. Our old camper had the same fridge and had three shelves. We also looked at the brochure online which shows three shelves. We called the dealer and they ordered the missing shelf under warranty. The missing one is a full-size shelf without the cutout.
Dave & Gean
2007 Tundra DC 4X4 5.7
2009 Cougar 245RKS
370 watts ET solar
Rogue 3024 MPPT controller
440 Ah battery bank
ProWatt 2000 inverter
ksg5000
Oregon
Posted: 04/16/12 10:18am Link  |  Print  |  Notify Moderator
Sounds like the same setup my fridge has -- two large wire frames (one with hole cutout for milk) and one small one just below cooling fins.
Kevin
