RV.Net Open Roads Forum: Toy Haulers: water system confusion
Search only in Toy Haulers
 > water system confusion
christopherglenn
a little over an hour from Yosemite
Posted: 04/15/12 10:17pm Link  |  Print  |  Notify Moderator
pressure switch is fine - it runs when there is no pressure, and shuts off if there is (city pressure). Sounds like either the inlet line from the tank is blocked (hard to pump vaccum), or it (the pump) is sucking air - either from the line to the tank (how long does it take to prime?), or a leak in the suction line letting air in.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
jetenbu
Southeast Texas
Posted: 04/16/12 07:16am Link  |  Print  |  Notify Moderator
There have been other posts here about clamps being loose letting the pump suction air into the lines and not pumping water out. Go to each and every clamp and tighten them up and you may solve your problem.
I hope this helps....
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
MadMav
Colorado Springs, CO
Posted: 04/16/12 09:08am Link  |  Print  |  Notify Moderator
Water pump will not pump water unless the water heater is in normal config(non-winterized).
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
drwwicks
Alabama
Posted: 04/16/12 09:11am Link  |  Print  |  Notify Moderator
Fixed it. I took the pump out and apart and everything looked good. Bench tested it and it drew a suction. Put it back in and same problem. I started turning valves. Put the "winterize" valve in the ON position, the pump began to suck water and ran good. Maybe I understand valve labeling different from Keystone, but I would think that "winterize" ON would be the position to winterize the plumbing, not normal use.
Did I mention the owner's manual was useless in information.
Anyway, now I can sanitize the thing.
Thanks for all the help here. I am going to check the tightness of connections since the panels are off.
2011 Keystone Raptor 300MP
2012 Ram 3500 CC Dually
2011 Harley Davidson FLHTK
joebedford
Jasper, Ontario
Posted: 04/16/12 05:37pm Link  |  Print  |  Notify Moderator
Mine does. I have two valves: one for water heater bypass and one for winterize. Pump works with former engaged but not the latter.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
MadMav
Posted: 04/16/12 05:50pm Link  |  Print  |  Notify Moderator
You really turn them both(bypass valves) off/on at the same time. That's what I said/meant.
To have the label backwards on the OPs trailer caused the confusion. Glad it was found.
Mav
* This post was edited 04/16/12 06:26pm by MadMav *
joebedford
Jasper, Ontario
Posted: 04/16/12 06:37pm Link  |  Print  |  Notify Moderator
Mav
Yes, I'm glad the OP solved his problem.
However, there have been many times that I do NOT operate the bypass and winterize valves at the same time. I'm quite prepared to risk my fresh water freezing in the holding tank but not in the hot water tank. In really cold weather, I winterize all fresh water tanks and lines, but don't worry much about the black and grey tanks; in moderate cold weather, I drain the hot water tank but use my fresh water tanks.
Searching_Ut
Utah
Posted: 04/16/12 07:18pm Link  |  Print  |  Notify Moderator
Good Job tracking the problem down. The manual in my Keystone isn't of much use either. It's a book for everything they make I believe, and doesn't list anything specific like where the valves, pumps switches or anything else happens to be. To make it even worse, what labels there are, often aren't correct. They didn't even get the labels right on the Black and Gray tanks even though it's the type where the valves are right out in the open and you reach down and manually slide the valve. I guess they just like making it a game to find out where things are, and how they work.
drwwicks
Alabama
Posted: 04/16/12 09:02pm Link  |  Print  |  Notify Moderator
Mine has a sewer hose compartment below the water service area that has pull levers for the black and grey tanks plus there is a smaller grey drain coming from the middle of the trailer that "T's" into the drain pipe just before the sewer hose connection. The under carriage is insulated so not sure if there are 2 grey tanks. Maybe 1 for the kitchen sink and the other for the bath??
MadMav
Posted: 04/17/12 10:22am Link  |  Print  |  Notify Moderator
Mav
You are confusing me on this. There are two bypass valves usually for the water heater and a seperate winterizing port/valve. I don't use the winterize, but do use both bypasses while winterizing.
Mav
