RV.Net Open Roads Forum: Travel Trailers: Slide safety switch
 > Slide safety switch
hhornig
Eagle, NE
Posted: 04/15/12 08:40pm Link  |  Print  |  Notify Moderator
I am at a campground and the neighbor just pulled in with a new 32' Monte Carlo and can't get the slides to move out. Since I don't have slides, couldn't help him. It seems to me there should be a safety lockout to prevent kids from moving the slides. Am I correct and where would it be?
spike99
North America
Posted: 04/15/12 11:17pm Link  |  Print  |  Notify Moderator
To stop kids from "playing" with my TT slide's power switch, I simply pull its 12V fuse. Kids (or unknowing adults) can play with its slide switch all they want, and nothing will happen. If slide doesn't work, check its 12V fuse as well...
LarryJM
NoVa
Posted: 04/16/12 01:02am Link  |  Print  |  Notify Moderator
A lot of slides don't have a fuse, but use a self setting CB tied directly to the battery.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
the_happiestcamper
Mount Pleasant, SC
Posted: 04/16/12 05:34am Link  |  Print  |  Notify Moderator
His battery may be weak - slides operate only off the battery, not off the converter - converter can't handle the load of a slide motor.
Jon, Freesi, Lars, Tucker, Holland
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
JimInMich
Mi
Posted: 04/16/12 11:42am Link  |  Print  |  Notify Moderator
Not on my TT. I have a factory battery cut off switch. Before storing for the winter, I double checked that it shut power to the TT ( no lights and slide didnt work ). I pulled it into it's parking place at my home and plugged it into the 30Amp RV outlet I installed for it. Now my lights and slide are working and I have not switched the battery back on yet. Yup, suprized me too.
And to answer the OP question, mine does not have any slide switch, other than the one to make it open or close. Have him check his fuses.
11 Chevy Silverado Ext.Cab Z-71 4x4, 5.3 v8, 3:43 w/locker, Factory tow package, Equal-I-zer 1200#, Curt Class V Receiver
12 Cougar XLite 27RLS ( 960# Tongue, 6740# Gross as loaded)
Just the Wife and I.
knesdad
Wisconsin
Posted: 04/16/12 12:13pm Link  |  Print  |  Notify Moderator
On our previous (KZ) trailer, the slide in/out switch was on the backside of the dinette seat. Low enough for little hands to play with, so they had another on/off switch for supplying power to in/out switch. It worked well...
On the new trailer, the switches are much higher up and out of the way, so no more on/off switch for the slideroom.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
Bucky Badger
Madison, WI
Posted: 04/16/12 12:40pm Link  |  Print  |  Notify Moderator
This is false..our 18' slide doesn't need a battery
..probably should have said "some slides....."
* This post was edited 04/16/12 01:15pm by Bucky Badger *
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
