RV.Net Open Roads Forum: Tow Vehicles: Allison tranny/eng oil cooler upgrade
Search only in Tow Vehicles
 > Allison tranny/eng oil cooler upgrade
Fastfwd101
Mt Home Idaho Via TEXAS (Air Force)
Posted: 04/15/12 08:51pm Link  |  Print  |  Notify Moderator
Has anyone upgraded their allison tranny cooler? Looking for adivice on which to use/not use and if it has helped out at all. also on eng oil cooler.
I have an 05 Duramax/Allison. Thanks for any info.
05 2500HD Duramax/Allison
3:73/4X4/CC
08 31Ft Keystone Energy TH
89 17.5 Stratos FS
bob213
Fresno, CA
Posted: 04/15/12 10:08pm Link  |  Print  |  Notify Moderator
Doubt that you need a different trans cooler. If you are experiencing high trans temps you are probably experiencing an inherent '05 problem. Google "thermal feedback" or look for posts by "Killerbee". A different turbo mouthpiece and induction tubes usually fix the problem for alot cheaper than any other remedy. Try beekiller@cox.net
christopherglenn
a little over an hour from Yosemite
Posted: 04/15/12 10:49pm Link  |  Print  |  Notify Moderator
Google "Mike L. cooler". for a allison cooler,
and "killerbeeperformance" for engine / oil cooling.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
RCMAN46
NorthWest
Posted: 04/15/12 10:55pm Link  |  Print  |  Notify Moderator
The Killerbee fix was not for overheating transmissions. The most common cause of an Allison overheating is overfilling the transmission. Double check your fluid level. Best to run it a little low than over full.
What were your temperatures and under what conditions?
Golden_HVAC
Fulltime, CA, USA
Posted: 04/16/12 12:48am Link  |  Print  |  Notify Moderator
One thing to check or just replace is the thermostat. They run on a little bit of wax, that as it melts expands, pushing against a spring, to open the water flow. If only a tiny amount of wax escapes, it will stop working right, and the engine will overheat.
Put the thermostat into boiling water, and see how far it opens. Better yet, replace it with a new one, they don't cost more than $20.
I had a friend that has a Mitsubishi, and it constantly overheated. He installed a hydraulic reservoir cooler on his engine, the thing never overheats anymore! I think the cooler has 1" lines and is only about 14" tall and 7" wide, 4" deep. The tubing makes about 6 passes, and comes out at around 120F. This cools the engine by getting rid of about 1/3 of the heat.
Fred.
Fastfwd101
Posted: 04/16/12 05:58am Link  |  Print  |  Notify Moderator
She does not run hot all the time, only when pulling TT in the hills. I'm easy on the pedal and normally
in tow haul mode.
killerbee
PHOENIX USA, Never hot
Posted: 04/16/12 08:05am Link  |  Print  |  Notify Moderator
In the 05, the transmission temperature is dependent on cooling system effectiveness, because of the liquid/liquid heat exchange between them in the radiator. Any changes that you make to improve cooling system performance, will lower transmission temperatures.
There are other ways to approach it also.
Michael, Systems Engineer and Professional DURAMAX Diesel Tuner
Killerbee Performance
ib516
Up here!
Posted: 04/16/12 08:08am Link  |  Print  |  Notify Moderator
in tow haul mode.
Typical. There are fixes out there.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
RCMAN46
NorthWest
Posted: 04/16/12 09:05am Link  |  Print  |  Notify Moderator
Until we get some temperatures from the OP we do not know what is overheating. An overfilled Allison will overheat without the engine temperature beyond the limits. We need more information from the OP. From what I read I was of the impression his transmission was overheating but then what some consider too high is often well within normal operating temperatures.
bob213
Fresno, CA
Posted: 04/16/12 09:51am Link  |  Print  |  Notify Moderator
The Killerbee fix may not have been designed for high trans temps but it does have a direct effect on it. My temps dropped quite abit....
