RV.Net Open Roads Forum: Tow Vehicles: New Ford truck question
Search only in Tow Vehicles
 > New Ford truck question
esfd243
East Syracuse, NY
Posted: 04/16/12 01:41am Link  |  Print  |  Notify Moderator
I have looked at the big 3 brand names diesels and I currently own a 2006 5.9l CTD. My question is why does the Ford have a 331 gear with optional 355 and the others have a 373 with optional 411? Does the 355 perform well with a 6 speed tranny? Thanks for the help !
Mike, Dawn & Mallori
2011 Keystone Cougar 324RLB (1st 5th wheel)
2012 Chevy 2500 HD D/A 3.73
Huntindog
phoenix arizona USA
Posted: 04/16/12 02:55am Link  |  Print  |  Notify Moderator
I belive that Dodge is still offering 3 ratios with differing tow ratings.
Ford has different ratios paired with differing tire sizes (which affects actual ratio) but the same tow ratings for all of them. GM has one ratio. 3.73.
The Ford has a lower 1st and 2nd gear in the tranny than the GM, and a taller 3rd gear. This leaves a hole in the gear pattern which is a disadvantage compared to GM. It is the primary reason that the GMs exhaust brake works better at highway speed. Of course the tradeoff is a little better aceleration in the 1-2 gears, and possibly better EB performance at slower speeds. I have never seen a test to verify this though. Probably because at slow speeds most are comfortable without a exhaust brake anyways.
But back to the original question. You cannot look at just the axle ratios. Tire height and tranny gear ratios affect the final ratio.
SO you have to do some math to find out which is the more capable truck.
I will say this. When one manfactureer is offering 3 ratios with differing capacities and the others are not, then that means that they are working around a weak link in the driveline. In this case it's probably the tranny.
* This post was edited 04/16/12 03:58am by Huntindog *
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
NewsW
US
Posted: 04/16/12 07:07am Link  |  Print  |  Notify Moderator
Less power output, unable to rev as much, also factor into it.
Technologically, the engine is too old for the job.
catfishmontana
montana
Posted: 04/16/12 07:18am Link  |  Print  |  Notify Moderator
I have a 2011 Crew Cab, Long Box, 4x4, lariet with the 3.55's. It pulls our 11,500(ish) TT wonderfully. All my previous diesels were 3.73, and this truck out pulls all of my previous ones. Like said, the first gear is really deep.
Mine ~ 2012 Ram 3500 Dually, CrewCab, Longhorn, Cummins
Hers ~ 2012 Ford F150 Raptor, Blue Flame, Crew Cab, 6.2L
GONE!!! 2010 Chevy Tahoe LTZ 5.3 ~ Most worthless POS ever!
2007 Keystone Montana Mountaineer 30FKD TT
ricatic
Home
Posted: 04/16/12 07:47am Link  |  Print  |  Notify Moderator
I was an early buyer of the 6.7 powered Ford. My truck has the 3.55 gears and 20 inch rubber. I have towed the 13000 pound Big Horn over 12000 miles now with no issues regarding sufficient power or the engine brake.
This question was asked a lot earlier in the game over at the Ford forums. In all the discussion I have seen, not one owner has complained about either the 3.31 or 3.55 gearing.
As long as the truck keeps running, it will pull anything within it's ratings anywhere you want to drag it...
Regards
Ricatic
Debbie and Savannah the Wonderdachsund
2009 Big Horn 3055RL
2006 Chevrolet Silverado 3500 Dually LTX with the Gold Standard LBZ Engine and Allison Transmission
2011 F350 Lariat SRW CC SB 4WD 6.7 Diesel POS Gone Bye Bye
1jeep
acushnet ma.
Posted: 04/16/12 07:40am Link  |  Print  |  Notify Moderator
I second whAt catfish stated as mine also came with 3:55 and it out performs my previous 08 f350 with 3:73 and 5 speed tranny.
2011 F250 CC LB, 6.7 urine injection
2007 keystone Outback Sydney 32BHDS
2009 HD Ultra CVO
2013 CanAm Outlander 1000
1963 Wife..no mods
Biggziff
Upstate, NY
Posted: 04/16/12 08:38am Link  |  Print  |  Notify Moderator
Like Ric...I read lots of this early on. There is so little difference between the gearing and the new engines have so much power that you won't notice a difference.
Me and my 3 girls
2013 Cougar 293SAB
2011 F350 CC SWB 6.7
tkcrawford
Edmonton, Alberta
Posted: 04/16/12 08:58am Link  |  Print  |  Notify Moderator
Man, where in the world do you guys come up with this stuff?!
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600
2008 Eagle Cap 995
4x4ord
Canada
Posted: 04/16/12 09:36am Link  |  Print  |  Notify Moderator
Even the high speed rear end in the Ford (3.55) will deliver over 10,000 ft lbs of torque to the rear axle in low gear. Traditionally the Ford torque converter has been able to almost double that torque if necessary at launch. This means that the new Ford with the 3.55 rear end could be capable of delivering nearly 20,000 ft lbs to the rear axle at launch.As a comparison your '06 Dodge is capable of just over 5000 ft lbs to the rear axle with 3.73 gears and in low gear. I use my F350 in very soft ground with trailers of over 30,000 lbs behind it and this incredible torque is the one thing that most impresses me above all else on this truck.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
4x4ord
Canada
Posted: 04/16/12 09:53am Link  |  Print  |  Notify Moderator
Keep in mind that if you are going down a 7% grade in the mountains with 20,000 lbs hooked to your truck 60 mph is quite a speed. (I think that is too fast) The GM will downshift into 2 nd gear and hold the truck at 60 mph and 4200 rpm. The Ford would need to solw down to around 45 mph to shift into 2nd gear where it would hold at a little slower engine rpm and safer speed of descent.
