RV.Net Open Roads Forum: Tech Issues: $600 crimper versus a $15 crimper?
 > $600 crimper versus a $15 crimper?
mlts22
Austin, Texas
Posted: 04/16/12 11:58am Link  |  Print  |  Notify Moderator
I know this sounds dumb, but what is the difference between a $600 crimper tool from Grainger versus a $15 tool from the hardware supply store of choice, and for using one for joining wires? Does it make that much of a difference for the long haul in RV/automotive work?
shutdown
In The Dog House
Posted: 04/16/12 12:04pm Link  |  Print  |  Notify Moderator
About $585. Seriously, it is about a few things: first the high end ones are electric, air or otherwise powered to crimp. They also handle a wider range of sizes of wire think heavy industrial stuff.
For personal use i think a 15 one will serve you fine. A nicer one in the $30~$50 range will last a lifetime.
smkettner
Posted: 04/16/12 12:11pm Link  |  Print  |  Notify Moderator
How about providing a link to the two you are comparing?
I imagine $600 will crimp bigger wire with less effort.
I use the $60 Harbor Freight hydraulic crimper for #8 or larger.
http://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html
675 watts solar
2oldman
Winchester WA
Posted: 04/16/12 12:12pm Link  |  Print  |  Notify Moderator
Quality of construction, intended use, ease of crimping.
Happy Harry
Redding, California
Posted: 04/16/12 12:15pm Link  |  Print  |  Notify Moderator
The difference between a $600 dollar tool and a $15 dollar tool is exactly...$585 dollars. And NO you don't need the $600 dollar tool.
Now the real answer to your question.
The tool that you need to crimp wire connections in your RV or your boat wireing is a ...KLINE 1005 crimping tool.
You can buy one on line for about $15 bucks. When you are crimping the crimp sleeves, be sure that the tool you use will put a DENT into the sleeve, some cheap crimping tools just flatten out the crimp sleeve..The Kline #1005 crimping tool works on both insulated and non insulated crimp sleeves, and is built to last a life time.
Mine is very, very old and still looks and works like it's new.
Good wire connections to you...
Harry
halibutman214
Oregon
Posted: 04/16/12 12:39pm Link  |  Print  |  Notify Moderator
The government is buying the $600 crimper?
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
Acampingwewillgo
Posted: 04/16/12 12:51pm Link  |  Print  |  Notify Moderator
If your talking large wire crimpers, the "Impact Crimpers" are fairly inexpensive and Amazon lists a number of Compound Crimpers from 100-200.00 bucks. The Kline 1005 is a small wire crimper.
96 Vogue Prima Vista 37' CAT 3176B
Our Babies: Mollie, Rubie, Cassie and Maggie, all rescued Cavalier King Charles Spaniels
Rainbow Bridge: Laddie, Scoutie, Katie, Cooper, Kodie
Rally's and get togethers.....Lots
smkettner
Posted: 04/16/12 12:43pm Link  |  Print  |  Notify Moderator
KLINE 1005 will not crimp a single wire the $519 Grainger crimper is designed for.
http://www.grainger.com/Grainger/IDEAL-Crimp-Tool-10F622?Pid=search
CJW8
Arizona
Posted: 04/16/12 12:48pm Link  |  Print  |  Notify Moderator
The $600 crimper probably meets certain specifications required for certain industries such as aviation and nuclear power. The expensive one is probably UL, CUL and CSA certified. Certainly wouldn't want the elcheepo crimper used in the nuke plant next door to me! They typically make the exact same crimp every time and are subject to repeatability tests. This is very important at 35000 feet or to make sure the auxiliary cooling water pump starts when it is suppose to...every time. Failure is not an option.
If we are talking simple hand crimpers, the $30-50 crimper is just fine for most folks.
2013 F350 PSD FX4 SB CC, 18,000 Superglide
2003 37SP Forest River Sierra Toyhauler (40')
2008 Polaris RZR
405 Watts of Kyocera solar panels, Rogue 3024 Charge Controller
bogen2
Edmonton
Posted: 04/16/12 01:09pm Link  |  Print  |  Notify Moderator
This is the one I got for $50 off eBay:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=230762212794
I've crimped #10 to #2 cables and it worked great.
2006 Ford F150 Supercab
2010 Jayco Jayflight G2 23FB w/ Reese Dual Cam WD hitch
190w solar, 1000w PSW inverter, Prostar PWM controller
