RV.Net Open Roads Forum: Class B - Camping Van Conversions: 2010 Roadtrek Sprinter
 > 2010 Roadtrek Sprinter
Tanya6520
Ft Pierce, FL
Posted: 04/16/12 04:29pm Link  |  Print  |  Notify Moderator
I am taking my grandson to Ohio this week and I need to keep him entertained with DVD's. How do I run the TV and DVD Player while driving down the road. Neither will come on.
SkipJ
Michigan
Posted: 04/16/12 04:39pm Link  |  Print  |  Notify Moderator
You need 120 volt AC. Can get with generator, or from an inverter which converts 12 dc to 120 volt AC. Or, buy a portable DVD player. How about he looks out the window at scenery ?
SkipJ.
1992 Airstream B-190 van
1989 Airstream 25' Excella Trailer
Outfitter Apex 9.5 Truck Camper Ford F-350 Diesel 4x4
Tanya6520
Ft Pierce, FL
Posted: 04/16/12 05:16pm Link  |  Print  |  Notify Moderator
Thank you for the info. He does look out the windows, but with two days of travel he gets bored just sitting. This will be the first trip for him in the Roadtrek, so he may enjoy the scenery from the wide open windows.
TMBLSN
Washington State
Posted: 04/16/12 05:17pm Link  |  Print  |  Notify Moderator
SkipJ.
18 hours of staring out the window? I could understand books, or something, but 18 hours of mind-numbing scenery?
Seriously?
midnightsadie
ohio
Posted: 04/16/12 05:30pm Link  |  Print  |  Notify Moderator
take the rv to a radio shavck store they,ll fix you up with a inverter you,ll be on your way.
mlts22
Austin, Texas
Posted: 04/16/12 05:33pm Link  |  Print  |  Notify Moderator
The easiest way would be to get a portable DVD player, if one doesn't want to put it onto 120VAC + inverter.
goreds2
OH H ..... EYE OH !
Posted: 04/16/12 09:02pm Link  |  Print  |  Notify Moderator
I have one of these. Kind of expensive but great to have. I run my TV off this.
http://www.amazon.com/Xantrex-XPower-Powerpack-Portable-Backup/dp/B000157TP8
See Picture In My Profile
1990 Dodge XPLORER RV Van- Purchased 10/15/10
Chick Magnet !
* Sportsman GEN154 2000 Watt 80cc Portable Generator *
XM Satellite Radio since 12/25/2004
Sold my Class C 1976 Dodge TEC Motor Home 9/25/10
1775
NY
Posted: 04/16/12 09:57pm Link  |  Print  |  Notify Moderator
Your 2010 Roadtrek has an inverter. Switch that on and your coach TV and the entertainment center/DVD player should come on. First turn on your Battery Disconnect switch (this must be on). Try this first with the motor running but without the van in gear. It should come on. Then put the van in gear and make sure that they stay on. I don't think that Roadtrek has installed a cutoff to the TV if the van is in gear. I know that others use the Roadtrek entertainment center while driving so the TV should work also.
Also if you have a generator in your Roadtrek, you could use that also to power the TV and entertainment center while driving. There is no problem running the generator while driving. Make sure you have propane in your tank as the Sprinter generator runs on propane.
Enjoy your trip with your grandson!
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
retired4fun2002
Ellenton, FL
Posted: 04/17/12 06:56am Link  |  Print  |  Notify Moderator
Been there, done that, ugh!! "Are we there yet....I'm hungry." Safe travels.
Handbasket
Asheville, NC
Posted: 04/17/12 07:32am Link  |  Print  |  Notify Moderator
Hours and even days of travel being entertained by looking out the window were a _lot_ less boring back 'in the day'. The roads ran thru non-sterile countryside, towns, and cities with things to look at and marvel over and wonder about. Real gas stations & restaurants, mostly different.
Typical interstate travel that way as a kid these days would blow great big chunks. Medians, trees, an occasional interchange, travel centers.... Great for making time and safety, little to no entertainment value.
Reads the van's manual, find the inverter. The power to run it will be essentially 'free' when the engine's running. If you lack a manual, it's probably downloadable from the Roadtrek website. Or to use a laptop for hours playing DVD's on the move, buy a cheap lighter plug-in inverter at most electronics stores.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
