RV.Net Open Roads Forum: Travel Trailers: propane alarm
 > propane alarm
beemerphile1
I'm 57, I'm not a
Posted: 04/17/12 11:48am Link  |  Print  |  Notify Moderator
I've never understood why when a safety device alarms people think the alarm is defective. Your first thought should be that you have an LPG leak. Have a pressure drop test performed on your system.
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
chuggs
CincyGus wrote:
chuggs wrote:
Do you have a dog?
Our Samoyed was sleeping with his rear near the detector... He set off the"gas" detector at 2:30 am on our last outing. Scared the heck out of us ---waking from a deep sleep.
Hilarious!
I have had ours go off on once in awhile for no apparent reason. I was always walking by it or had just opened or shut the bathroom door next to it. Still have not figured out what is causing it but if it continues, I'll be taking ours in to be replaced. It is pretty scary when it goes off enexpectedly.
We didn't know exactly what caused it. We just knew the dog was sleeping there. Then I googled to see if that would cause it to go off and found this guys you tube video. I fell out of my seat laughing at this guy. His kid's chuckling at Dad's crazzy antics had me holding my sides laughing.
You Tube Link
mking
Indianland,South Carolina
Posted: 04/17/12 12:22pm Link  |  Print  |  Notify Moderator
After 2 years of use ours did the same thing.I did check for gas leaks but found none.I also found out that any alchol based product will set the thing off to.Hair spray,open liquor bottle,jello shooters,sun tan products,and yes,methane gas!
2006 Dodge Quad-Cab 2500 CTD,4;10 gears,pulling a Forestriver Flaggstaff 831qbss
Dega500
Alabama
Posted: 04/17/12 01:14pm Link  |  Print  |  Notify Moderator
Here goes my first noob question. I have not performed a search on the subject like I should but why could one (or a couple) of these battery operated units not work in an RV?
http://www.bing.com/shopping/kn-cob-b-basic-carbon-monoxide-alarm-with-electrochemical-sensor/p/6AFFC627CE87B993E2C7?q=co+alarms&lpq=co%20alarms&FORM=HURE
kearlms
Rexburg, ID
Posted: 04/17/12 01:26pm Link  |  Print  |  Notify Moderator
Here is a CLICKY
Dega500
Alabama
Posted: 04/17/12 01:31pm Link  |  Print  |  Notify Moderator
Thanks
cyberiankhatru
Youngsville NC
Posted: 04/17/12 01:45pm Link  |  Print  |  Notify Moderator
vaccuum it out and blow it off with a can of air. that's all i did to mine and it quit going off in the middle of the night for no reason.
N7SJN
SE Washington State
Posted: 04/18/12 09:27pm Link  |  Print  |  Notify Moderator
Ours guit after 5 years of continuous use, simple to replace.
dixontravelstar
northwestern Illinois
Posted: 04/18/12 10:22pm Link  |  Print  |  Notify Moderator
thanks everyone. Love the story about the dog setting off the detector. I do have a dog, but she wasn't anywhere near the detector. And yes, it is the propane detector. Says so right on the alarm. After it went off, I turned off the propane and we opened the ceiling vent and turned on a fan. After awhile we turned the propane back on and closed the vent and turned off the fan. It didn't go off again after that. I will vacuum it and check the date on it when I get it out of storage again next week.
2011 Laredo 291TG
2007 GMC Sierra VortecMax
 > propane alarm
