jaycocamper62301
Illinois
You know you are not supposed to start a generator under load then what is the advantage of the Champion going to remote start? Aren't you still going to have to go outside and unplug and start then replug? Or did is there a delay built into the generator? Sorry for a dumb question in advance
2008 Ford F250 Crew Cab Short Bed 6.4 Lariat Dark Stone & Tan Sold
2008 Jayco 32 BHDS G2...SOLD
2011 Cyclone 3850 HD stone mocha inside
2011 F450 White Tri Coat, Chrome Package, FX4, Lariat
TEXAS
Centerville Tx
No such thing as a dumb question. Don't know your set up. But you should turn off all load before starting any generator or stopping it. Most RVs today have a transfer switch that will allow the genset to come up to speed and voltage. Before switching over.
Starting and stopping one under load. Is the main cause of voltage regulator failure.
2oldman
Winchester WA
jaycocamper62301 wrote: Aren't you still going to have to go outside and unplug and start then replug? Not if you have the ability to turn off the loads from inside the trailer first. Is that an inverter generator?
edited 04/17/12 07:52am by 2oldman *
Learjet
Louisiana
turn main breaker off inside (which should already be off, if you let the generator cool down for a minute before stopping), start, wait a minute or two, turn main breaker back on.
2013 Ford F250 XLT 2wd Crew Cab 6.2 and 3.73 rear
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Yamaha EF2600c Tri-Fuel Gen.
Champion Model 46595- 3000/3500
sold* 2001 Hurricane 30Q Chevy workhorse
sold* 2006 Nissan Titan CC with tow package
jaycocamper62301
Illinois
No don't have one...was just thinking the remote start advantage would be negated by having to go outside and re plug RV in. Wasn't sure if throwing the breaker was enough. Doesn't the RV's on board battery charger come on at all times?
M GO BLUE
Southgate, MI
I'm assuming we are talking about a portable generator?
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Sandia Man
Rio Rancho, NM
For what it's worth, everything is turned off with the exception of our rig's converter when powering up/down our onboard Onan.
mlts22
Austin, Texas
A lot of models with remote start have a relay that keeps the electrical load shunted off until the generator has been running 10-30 seconds. This way, you can shut the generator off and on from remote without having to connect or disconnect what is plugged into it.
2oldman
Winchester WA
jaycocamper62301 wrote: Doesn't the RV's on board battery charger come on at all times? Yes, but it may have its own breaker.
Using breakers for switches is not a great idea over time. You can easily find the 120v feed wires to the converter and install a switch.
deroh
Wilmington, Delaware
I have an Onan 5500 that had very similar symptoms. In my case it was the voltage regulator that was bad. Caused Genny to just shut down (not just stall). Not a cheap repair but better then a whole new Genny.
Dave
'98 Fleetwood Bounder 35'
Chevy 7.4L
Delaware
