dalehelman
Liberty Lake (Spokane) Wa.
Have a certified welding shop reinforce your frame and hitch to 10,000lb. Be sure to keep the paper work for the job. It cost me around $800 six years ago.
Dale & Sandi
2006 Jeep TJ 4.0 w/33s 4" lift
2008 Winnabago Adventurer 38T
Liberty Lake (Spokane) WA.
DIY Manual replacement for Workhorse Auto Park emergency brake.
Stay In Play Duo Toad Braking System
2inAlabama
Huntsville, AL
I agree with Doug. I think that you are courting disaster. You will be a danger to yourself, your family, and everyone else on the road.
Just DH & DW
RayChez
Barstow, Ca. USA
The V10 gets 8-9 mpg. That is what my 36'motorhome used to get.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
toolman1
Cerritos, CA.
dalehelman wrote: Have a certified welding shop reinforce your frame and hitch to 10,000lb. Be sure to keep the paper work for the job. It cost me around $800 six years ago.
Exactly what I did, threw in an equaizer hitch, and I converted the trailer brakes to discs on both axles. It stops on a dime and gives back a nickel in change.
See ya out there!!
Hooliville member #128
Gary & Lynne.
'04 Dolphin 5320 WH-22 370W Solar
22' Mighty Mover Trailer, 60W. Solar.
Sand Sprite 4. 2.3L EFI sand buggy
'04 Polaris Predator
'84 Jeep CJ.
2011 Black Lab "Lucy" for both of us
Effy
MD
toolman1 wrote: dalehelman wrote: Have a certified welding shop reinforce your frame and hitch to 10,000lb. Be sure to keep the paper work for the job. It cost me around $800 six years ago.
What did they do exactly? I have a friend who owns a metal shop and would gladly do this for materials.
2012 Thor ACE 29.1
roam1
Gulf Breeze FL
Keep in mind the Gross Combined Vehical Weight Rating too, you may not legally have any CCC left, don't know.....
why push it to the limit? if you have to tow that much maybe a super C or DP???
your choice obviously, we all pick out paths, happy trails!
Doug and Cassi Glass
Clifton Forge, VA
Beefing up the hitch WILL NOT strengthen the other components already discussed. There are lots of used diesels out there in your price range that can SAFELY tow 6500 pounds.
There are certain things in life that we have to trust the experts about like open heart surgery, nuclear propulsion, etc. unless you happen to be an expert in that particular field. I make no claim to be a vehicle design expert so therefore trust the expertise of those who do design them. They look at the safety aspects as well as the civil liability aspects of designing a safe vehicle.
If you do tow a load so much over weight you are making a HUGE, HUGE mistake that could cost you financially in repairs from damage done overloading the systems, financially in lawsuits for damage or injuries to others, or injuries to your own family.
topflite51
In The Desert of Nevada
Why chance it? For 91K out the door there are definitely DP's out there with the tow capacity you require to make it totally unnecessary. Then there is also the issue of Ford's drivetrain warranty, what happens when/if something goes wrong?
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
restorodder
Pinckney Michigan
The Ford V10, 2006 and later is an awsome engine. 362 HP is all I need. We just came back from Florida,on I-75,towing a 4800# toad. I had trouble keeping the speed under 70 without the cruise control. Uphill,through the Smokey mountains,was not a problem. only once slowed to 55MPH at 4000 RPMs. Most hills were taken at 3500 RPMs,and 62MPH. I have never gotten more than 6.7 MPG towing,or less than 5.9MPG. The car and trailer in my Avatar weighs 5000#,and our Grand Cherokee on the same trailer is 6000#.
2008 Newmar Canyon Star - 2007 Dodge Dakota Toad - Ready Brute tow bar & brake system - one cat - Sassy 14
Jim Norman
NJ
It is refreshing to see a thread with realistic MPG numbers. Our rig averages just over 6.3MPG. Interesting is that it all depends on where I buy gas. Last trip out NJ Gas, I got 6.3, coming home with West VA gas, I got about 7.6. This is while towing my Jeep Liberty.
The Ford V10 does the job nicely. Never at a disadvantage.
2009 Itasca Sunova 35J
2008 Jeep Liberty (aka FireToad)
