RV.Net Open Roads Forum: Truck Campers: Happijac rust! (pics)
 > Happijac rust! (pics)
silversand
Montreal
Posted: 04/18/12 06:57am Link  |  Print  |  Notify Moderator
I like that plastic cap blocking the manual jack holes! Wish I had those.
So far: keeping our jack rust to just about nil by waxing 2 times a season, and re-painting the minor rust spots. Our rig (and jacks) are just about 7 years old (no rebuild needed yet).
I just injected some lithium grease (with grease injector) into the top gear section of the four jacks 2 days ago on getting rig out of storage.
Silver-
Silver
bka0721
Republic of Colorado
Posted: 04/18/12 09:50am Link  |  Print  |  Notify Moderator
I wish mine looked as good as yours! Yep, things rust and sometimes maintenance is necessary. I like your response of wanting to find a way of maintaining these jacks. If you don't take the Camper off the truck, when traveling, consider removing them.
b
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
SJR
Philadelphia, PA
Posted: 04/18/12 09:53am Link  |  Print  |  Notify Moderator
silversand wrote:
I like that plastic cap blocking the manual jack holes! Wish I had those.Silver-
I ordered a part from the company and they sent me the part and a set of those covers free. I didn't ask for the cover or even know they existed. I bet if you contacted them they would send you a set.
Stephan
2010 Dodge 2500 Crew Cab
2003 Northstar TC800EC
2003 Jayco Kiwi 21C
Equalizer Hitch
Reddog1
El Dorado, CA
Posted: 04/18/12 10:30am Link  |  Print  |  Notify Moderator
I would be concerned with the rust I could not see, especially on the welds. If you see rust in front of the weld, do you not think there is rust under the Angle on the part of the weld you cannot see? Usually it is just a cosmetic issue, but not always. Without disassemble, I don't know how you could remove the rust you cannot see. I do not have Happy Jacks. If new, or no rust, I would consider a little calk on that edge and top. I would leave the bottom open.
I have very limited knowledge on powder coat, but from what I understand it is a good product. I think the problems come in if the metal is not prepared properly, before coating. I have seen many people paint over rust. The rust is still there getting worse.
Wayne
flaxi
Germany
Posted: 04/18/12 02:29pm Link  |  Print  |  Notify Moderator
thats normal.......... NO primer is used arghhhhh.
I grinded the Happijacks completely, put the primer and the the colour, and now all is ok.
Dodge CTD 2500/03 & Adventurer 810WS/04
GERMANY
ISBRAM
Denver, Colorado
Posted: 04/18/12 04:16pm Link  |  Print  |  Notify Moderator
KKELLER14K wrote:
Yep... mine look worse than that now...look at the tear down link and you could have them stripped an re-done. I'm thinking of having mine done in LINEX... stuff is tuff as nails....and they could do white if I'm not mistaken. The front edges have just been pelted from road rocks...going to look into that right now. Has any one ever done that yet???
Here is a shot of mine in white Line-X.
99' Ram 2500 QC 4x4 Cummins. F&R Roadmaster Anti Sway Bars, Air lift 5000's, Stable Load's, Bilstein's
11' Hallmark Cuchara XL 9.5
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
Super_Dave
Sacramento, CA
Posted: 04/18/12 04:31pm Link  |  Print  |  Notify Moderator
Is the factory finish paint or powder coat?
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
silverbullet02
Kingston, TN
Posted: 04/18/12 08:25pm Link  |  Print  |  Notify Moderator
Wayne
Exactly my thoughts. It's the metal behind the weld that you can't get to that's bugging me. Fixing the outside is no big deal, but that rust inside will just keep growing again.
2007 Dodge 2500 QCLB, 5.9 Cummins---Roadmaster sway bar, Rancho RS9000's, Firestone air bags, Rickson 19.5 wheels, Michelin XDS2 225/70's.
2007 Arctic Fox 811
Reddog1
El Dorado, CA
Posted: 04/18/12 09:04pm Link  |  Print  |  Notify Moderator
silverbullet02, that was my point. I think of it the same as dry rot. Pretty outside, rotten on the inside.
silverbullet02
Kingston, TN
Posted: 04/18/12 10:14pm Link  |  Print  |  Notify Moderator
Yep, so that brings me back around to the original question. I wonder if there's anything I can spray in there or pour in the cracks to stop or even slow down the rust inside.
On a side note, that is pretty cool with the white line-x on the outside! How easily to bugs come off of it? I know that it's bad enough sometimes getting the bugs off of my smooth powdercoat finish.
