pappaone
Colorado
I have a direct tv receiver from my home zip code, was wondering if I can go into the set up site, change the zip code to where I am camping and then change back to the old zip code later on.
Thank you
Rich & Jennie(mate of 53 yrs 6/6/59)
1 spoiled cat
2004 Sea Breeze 1341
2004 Malibu toad
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
Yep, sure can. If you are more than 150 miles or so away from your home zipcode, you will not be able to get your local channels, but can get the rest of them. Use your antenna for some locals to where you are.
JoeGood988
S.Dakota
When you go online, you will see a billing address (where your home is and where the bills come to) and a service address. The service address is where you are parked, that's what you change. As I move around the country, I change the service address to obtain the local channels and get a signal.
2003 3330 Jayco Legacy
K Charles
Connecticut
The dish may need to receive signal from two satellites to get locals.
Cimriver
Colorado
I see you are from Colorado. Our locals are the Denver channels. We can get the locals as far away as Moab, UT. That's about 400 miles driving. Don't really know how far as a bird flies. So if they are Denver locals you should get them a little farther than 150 miles.
Gordon & Patti
2008 F-350, 6.4L. Power Stroke, CrewCab
2012 Dutchmen Komfort 3130FRL Fifth-Wheel
Be Safe!!!!!
Crazy Ray
Monroe,La
You only put Zip Code info to get azimuth & elvation. OP said nothing about locals. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
accsys
Green Cove Springs, FL
pappaone wrote: I have a direct tv receiver from my home zip code, was wondering if I can go into the set up site, change the zip code to where I am camping and then change back to the old zip code later on.
Thank you
You absolutely can however, you should understand that only the pointing instructions change so that you know where to point the dish. The zipcode setting in the receiver has absolutely nothing to do with what channels you receive or what time zone you are in.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
rhochnadel
Colorado
Yes you can. Should be able to receive Denver channels as far south as Albuquerque, as far north as Rapid City, west to Moab, can't say about east.
the zip code you put into the receiver is just for aiming your portable antenna, you do not have to change your billing address nor the address you are located. They do not know where you are.
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"
sdianel
Tampa, FL
In reply to: JoeGood988, I just went online to the DirecTV website into my account and there is a billing address and an "installation address". There is no way to change the installation address without calling DirecTV and initiating a move. There is a "Move?" button underneath the installation address. When you press the button, the instructions say to call DirecTV. Can you tell us where the service address is located and how to change it? thanks
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
CA Traveler
The Western States
The zip code only tells you where to point the dish, nothing more. Once you are out of your local area spot beam call DTV with a new address and they will connect you to new local channels. Your billing address will not change.
JoeGood988, If there is a DTV service address online please provide more information.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
