koda55
Jacksonville
I have a 2005 Georgie boy Landau on a f53 2004 chassis. The electrical outlet for the rear tv and the one under it on the wall that I use for the clock do not work. All the other 120 volt work in the motorhome. I reset all the 120 fuses and it did not help. I popped and reset the GFI outlet in the bathroom and it did no good.
Any ideas on what to try next. I have the owners manual but it really doesn't help.
tahiti16
Camarillo, CA
Check circuit breakers for your inverter. The inverter will switch itself out of the circuit when shore power is applied but it still uses the c/b to protect the circuit.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
rk911
Wheaton IL
you might have another GFI somewhere...maybe in a compartment? we've got three in our MH.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
RayChez
Barstow, Ca. USA
Take the cover off the outlet and check to see if you have power on the wires to the outlet. Maybe it is just a bad outlet.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
enblethen
Moses Lake, WA
Get your self one of the circuit testers that plug into the outlet. Sere what is wrong, it could be a defective connection in the previous receptacle.
tester
Some Harbor Freight have less expensive models.
It could also be the GFCI feed thru feature is bad.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
CA Traveler
The Western States
IF none of the above: Use a tester to find all dead plugs. ALL including lockers, block heaters, HW, refer, etc. Open each plug and check for voltage and hopefully you'll find a loose connection. It's also possible that the loose connection is on the output side of a working plug.
A wire tracer can also be a big help. Pull the power plug and both negative battery cables so that there can be no inverter or gen power. Connect the wire tracer to one of the plugs and trace the entire circuit. Pull any cords that are plugged in. This will lead you from a dead plug (identified above) to a live plug or CB and the problem is at or between the two. Keep a record of how the circuit is wired for future reference.
If you don't know about AC safety then hire someone to find the problem.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
donsuefuggrwe
myrtle point ,or 97458
Had it happen today when I plugged the vacuum cleaner into a ground fault protector. Tripped the ground fault and would not reset. Third time this has happened. Go to your inverter and find the phone type connector to your furnace control in the coach. Might be two of the phone plugs. Might have one or two of the voltage breakers on the inverter tripped. Reset the breakers and pull one of the phone plugs out. Then trip the two breakers back and forth on and off a few times. Put phone plug back in and go back into coach and reset ground fault. If it doesn't reset, back to the inverter and repeat process pulling the other phone plug. Back inside and reset ground fault. Mine resets with this procedure. Don't know why but was told this by factory inverter tech support years ago. Good luck, let me know if it works.
koda55
Jacksonville
Thanks everyone for all the great info. I finally found an electrical box in my cable bay. After opening I found wires that had come out of the wire nut. Who ever wired the coach cut the wires to short and had pressure on the wires and they pulled apart. After moving the box and connecting the wires and using the socket tester everything works as advertised.
CaliTexican
California
Hello all, I am new to RVing, I also have no power to the back outlets. I have been unable to locate the breaker box referred here with phone jack type plugs. Where is this located, I own a 2004 Landau.
RayChez
Barstow, Ca. USA
You probably have a GFCI outlet that tripped. There is one in the bathroom and two usually in the kitchen area, Press the reset button and see what happens. If not then check your AC circuit breakers to see if they are not tripped. Usually in the bedroom around the bed box.
