RV.Net Open Roads Forum: Tow Vehicles: My Ram is in the hospital
Search only in Tow Vehicles
 > My Ram is in the hospital
notruffinit
Minnesota
Posted: 04/18/12 07:35pm Link  |  Print  |  Notify Moderator
dodge guy wrote:
JimInMich wrote:
2011 model and had a trans line failure already?
WOW! it only took 6 posts to get that response! LOL
I bought a new 2011 off the dealers lot 6 weeks ago. It has only 1100 miles on it. New warranty and everything. Odo reading of 200 miles when I got it home, so, yeah, I would consider that NEW.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
DUO_CORE
Mickleton
Posted: 04/18/12 07:44pm Link  |  Print  |  Notify Moderator
See! This is why I won't buy a Cummins!
2006 DRW 4x4
2006 5th Wheel
45Ricochet
North Idaho
Posted: 04/18/12 08:00pm Link  |  Print  |  Notify Moderator
Why? Is that ATF from the engine or what?
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
bmanning
Phoenix, AZ
I wouldn't be too discouraged if I were you; stuff happens, and though I'm sure you are/were a bit annoyed it certainly wasn't a catastrophic failure or anything along those lines (pardon the pun).
After your first successful tow/camping trip you'll forgive her
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
FishOnOne
Katy
Posted: 04/18/12 08:21pm Link  |  Print  |  Notify Moderator
FishOnOne wrote:
If your tranny temp did not overheat your probably OK.
As a precationary step I would have the dealer flush the tranny and add new fluid if you think it might have ran low on fluid.
Let clarify "Flush" means flushing the trany with heated trans fluid. It's pretty much the best method to remove any old fluid and some of the metal particles and for alot of shops the standard way to change the trany fluid.
Good Luck...
dfb
gardnerville
Posted: 04/18/12 08:25pm Link  |  Print  |  Notify Moderator
Id' just fix the line and fill it to the full line... Shoot, when I rebuilt engines the auto had to be refilled... Not to worry about flushing, filters, radiator etc....
JimInMich
Mi
Posted: 04/19/12 11:05am Link  |  Print  |  Notify Moderator
There's a problem with my responce? It may seem normal to you to have such a failure on a new truck, but it is not normal to me. People are paying huge amounts for a vehicle now a days, the manufactures should be making sure there are not these kind of problems.
11 Chevy Silverado Ext.Cab Z-71 4x4, 5.3 v8, 3:43 w/locker, Factory tow package, Equal-I-zer 1200#, Curt Class V Receiver
12 Cougar XLite 27RLS ( 960# Tongue, 6740# Gross as loaded)
Just the Wife and I.
ib516
Up here!
Posted: 04/19/12 11:28am Link  |  Print  |  Notify Moderator
2 pages of replies for a busted PS hose. Imagine if it had blown a turbo, or a head gasket, or a HPFP.....oh...wait...
Hey, just so all the haters know, I just recently had to repair a power steering hose on my 5 year old RAM too. Scandalous!
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
45Ricochet
North Idaho
Posted: 04/19/12 02:29pm Link  |  Print  |  Notify Moderator
Still page 1 here! less clicks for those long broken frame threads
And I didn't see no report on the front drive shaft maintenance that was planned about the same time as the PS service I hate the lube part of the Ram front shaft. Hopefully that designer retired or got fired.
On the bright side its still working
Hannibal
Gas Station
Posted: 04/19/12 07:04pm Link  |  Print  |  Notify Moderator
Sleep well. No harm done. Pat yourself on the back for catching it before it had a chance to do any damage.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
