RV.Net Open Roads Forum: Class A Motorhomes: Backflow preventer with black tank flush
 > Backflow preventer with black tank flush
2inAlabama
Huntsville, AL
Posted: 04/17/12 07:42pm Link  |  Print  |  Notify Moderator
I have the No-Fuss Flush feature on my coach, allowing me to flush my black tank by connecting a water hose to a faucet and to a connection on the tank, then turning the water on. My owner's manual cautions not to use my potable water hose to perform the flush, but it says nothing about using a backflow preventer on the hose used to do the flush. Do I need to use one? If so, can anyone recommend a brand/source?
Just DH & DW
Stuck in first
Virginia
Posted: 04/17/12 07:55pm Link  |  Print  |  Notify Moderator
Mine is built in. I think it is a requirement. When you disconect the hose the water up to the backflow preventer will run out but it will be fresh.
Dick_B
Palos Heights, IL USA
Posted: 04/17/12 08:29pm Link  |  Print  |  Notify Moderator
X2
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Executive
Posted: 04/17/12 08:30pm Link  |  Print  |  Notify Moderator
That caveat is so you don't contaminate your fresh water hose. Get yourself a cheap green or black hose from Home Depot. 25' is sufficient. Use that hose ONLY for your no fuss flusher. Keep your fresh water hose separate from anything connected to the black tank....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
belairbrian
Alabama
Posted: 04/17/12 09:13pm Link  |  Print  |  Notify Moderator
While I agree with a dedicated hose, i don't agree with a cheap hose from Home Depot or where ever. Yes you can get one for $10. But Sears will sell you a quality rubber hose for $23. And if it ever goes bad they will give you a new one for FREE.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
2inAlabama
Huntsville, AL
Posted: 04/18/12 07:02am Link  |  Print  |  Notify Moderator
My question has nothing to do with the hose. I understand that I need to use a separate hose to flush the black tank. Do I need to use a backflow preventer with it? Maybe I just need to contact Tiffin to find out if one is built into the system. Thanks anyway, Guys.
belairbrian
Alabama
Posted: 04/18/12 07:37am Link  |  Print  |  Notify Moderator
Heaven forbid someone other than you might read your post and get information.
TexasH
Katy, TX
Posted: 04/18/12 08:33am Link  |  Print  |  Notify Moderator
Use one of These anti siphon valves on your hose to prevent any backflow from the tank into the water system. I put it on the end of the hose attached to the faucet. I also use a Shutoff Valve where the hose connects to the flusher. Makes it easy to turn water on and off while flushing, and by turning off the water here before turning off the faucet, it prevents any backflow into the hose when it is disconnected.
2002 Southwind 37U Ford F53 - V10
2007 Jeep Liberty Toad
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/18/12 09:21am Link  |  Print  |  Notify Moderator
You need to keep a sense of humor on this forum.
It put a black tank flush on my last trailer and used it all the time without a back flow preventer. The trailer we have now has a flush installed and there is a back flow preventer. Somewhere along the way, plumbing codes have insisted that back flow preventers need to be installed anytime fresh water connections come in contact with sewer lines. If your coach is newer that 10 years old, I suspect you have one. I you don't, you don't NEED one.
I have no qualms about using my fresh water hoses on my flush, but that's me.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
xctraveler
Livingston TX
Posted: 04/18/12 09:24am Link  |  Print  |  Notify Moderator
It appears both of the items recommended by TexasH are plastic bodied. I have had enough plastic bodied hose fittings disintegrate over time that I have chosen to pay a bit more and buy brass fittings. Any plumbing supplier will have brass versions of the anti siphon device and the shutoff valve. Have only had one brass item (made in China) fall apart on me in service. Just my experience!
Make sure when you turn off the water at the spigot that you stand clear as the anti siphon device may spray water if there is any pressure left in the hose.
I rely on the required anti siphon device or check valve in the flusher connection to prevent backflow and turn off the valve so that pressure is relieved in the hose then disconnect the hose from the valve first so that the fresh water in the hose can flow out onto the ground rather than into my bay and I don't take an unplanned shower.
Paul
Trucking down the road in our new Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
