RV.Net Open Roads Forum: Tech Issues: Champion 2000 let me down last week
 > Champion 2000 let me down last week
RickBeer
Phoenix
Posted: 04/17/12 08:52pm Link  |  Print  |  Notify Moderator
I purchased 2 new Champion 2000 generators last November...Other than starting them up from initial purchase I never used them Until Last weekend for Country Thunder one of them wont idol will not smooth out the other one the pull starter is real freakin tight hard to pull & when it starts it overloads right away I called Champion & they directed me to a repair facility and advised me to bring in my receipt showing purchase is less than one year... I will post the results when they arrive
Frustrating
dqdick
Council Grove, KS
Posted: 04/17/12 09:17pm Link  |  Print  |  Notify Moderator
Thanks for sharing! Hope they fix it under warranty quickly. Let us know how it turns out.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
Old-Biscuit
Across the USA
Posted: 04/17/12 09:54pm Link  |  Print  |  Notify Moderator
That's what happens when equipment just sits around.....it doesn't work when you need it.
Hope they fix them under warranty.
When you get them back.....might want to exercise them once a month (run under load for 30 minutes) and treat the gasoline with SeaFoam or Stabil (fuel conditioner that will help prolong the shelf life of gas)......otherwise next time you want to use them, probably will have same problems.
SWD
Land of Living Skies
Posted: 04/18/12 01:34am Link  |  Print  |  Notify Moderator
Yuup! Good advice!
beemerphile1
I'm 57, I'm not a
Posted: 04/18/12 06:58am Link  |  Print  |  Notify Moderator
Check out this thread;
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24022161.cfm
- Soren Kierkegaard
markandkim
Swansea, MA.
Posted: 04/18/12 07:03am Link  |  Print  |  Notify Moderator
I use my champion all the time. I'd bet it has 500+ hours on it and it never skips a beat. Still starts on the 1st pull. Best $259 I've ever spent. Mine is a 4000w unit.
Retired Navy
2012 Ram 1500 Quad Hemi
2010 Amer-Lite 255BH
2004 Tracker 175 bass boat
dqdick
Council Grove, KS
Posted: 04/18/12 08:00am Link  |  Print  |  Notify Moderator
My Honda's have a little drain that clears the gas from the carburetor for when it's going to sit for a while. I would assume the Champions have a similar situation.
#40Fan
Colorado
Posted: 04/18/12 10:16am Link  |  Print  |  Notify Moderator
With the Champion, it is easiest to shut the fuel supply off and slightly tilt it to the back right corner. Then start it up and let it run the carb dry. Top off the tank and close the breather on the cap. Keep it in a cool area and you won't have any problems.
As for the hard pull, I had one like that. The module went bad and when I called customer service, they just sent me a new one, hardly any questions asked.
2005 Keystone Outback Sydney 31RQS
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
RickBeer
Phoenix
Posted: 04/25/12 07:39pm Link  |  Print  |  Notify Moderator
Well it has been over a week now since I dropped them off to a repair facility recommended by Champion tech support... The company has not even called... & for the last two days the business phone number is full can not leave a message.... I call Champion back they claim he is in good standings with them & they never received a call/order for parts from him for my generators... I stopped in today & was greeted by two other guys saying "BILL IS NOT HERE" NOT how can we help you they also claim Bill would not answer his calls & has not seen him in three days.... If I do not here from them by Thursday I have to call the police & have them reported stolen... I hope I am jumping the gun & I am wrong but when I dropped them off I had that gut feeling this is a shady deal Thanks allot Champion Tech Support
#40Fan
Colorado
Posted: 04/25/12 10:58pm Link  |  Print  |  Notify Moderator
Sucks to hear that. I hope that you get things figured out and it all works out in the end.
